Be aware that the cal hyop shock at walmart is NOT full strength. It is 45-48%. Normal strength is 68%. You will have to add more of it to reach the same ppm of chlorine in your pool! I believe 1 lb will raise 8000 gal to 10 ppm chlorine while full strength cal hypp will raise 10000 gal the same amount.
