Results 1 to 8 of 8
Thread: A shocking question
    Morris, IL
    Default Re: A shocking question
    How much ppm do you have to raise the chlorine to in order to shock? Now that I am on bleach I have been wondering about shocking with bleach. I seems that you would only have to add more but I may be wrong.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Quote Originally Posted by sevver
    http://www.poolforum.com/pf2/showthread.php?t=365
    This thread should answer that question.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Morris, IL
    Ok, my CYA is around 50, thanks that helps. I will have to do a dilution test in order to test for levels that high though, I need a better test kit. lol
