Thread: Should I bother to lower ALK of 110?
    Default Should I bother to lower ALK of 110?
    Lots of recommended ranges say 80-100 or 80-120, I always shoot for the middle, I was shooting for 90-100 and overshot to 110.
    Should I bother to bring it down a bit?
    Over winter it always drops in New England, will it drop much over summer on it's own?
    Default Re: Should I bother to lower ALK of 110?
    If you have a fibeglass or vinyl pool your TA is fine. If you have a plaster pool and your calcium hardness is not too high (say below 300 ppm) then you are fine also. If the calcium hardness is higher you might get some cloudiness if your allow your pH to rise so keep tabs on it and try to keep it below 7.8 at all times and you should be fine also!
    It really ain't rocket science! Just enjoy your pool and stop stressing over a possibly slightly high TA. If your TA was, say, around 190 THEN you should worry!
  1. Would you folks even bother??????
    By dansdad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 09:09 PM
  2. Why Bother??
    By ThaSatelliteGuy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2010, 01:12 PM
  3. Ph Lower after using BBB
    By Tillysaint in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-13-2007, 12:52 AM
  4. Lower PH?
    By MaxxFusion in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2006, 11:36 PM
