Closed Thread
Thread: Replaster?
    Philly Burbs
    Default Replaster?
    Last year I had my painted concrete pool of 22 yrs sandblasted and plastered. Anyone know the average life span of a plaster job before I ihave to get it done again?
    GutierrezPlastering Guest
    Default Re: Replaster?
    Quote Originally Posted by rollinrock
    Your water chemistry is the life of the Plaster, so if you keep it balanced properly it can last as much as 20 years. 20years is what i've seen some plaster go for.
    Jul 2006
    If you don't mind my asking, how much did the sandblast and replaster cost you? Also, how big is your pool? Thanks.
    Houston TX
    Another question...how do you know when replastering is needed? Our pool is 12 years old but looks good. Will there be cracks or something to indicate that a refinish is required?
    Quote Originally Posted by DogPaddle
    When it becomes Rough; u start to see brownish stains that won't come off, Indicating that the cement cream has gone and only the sand stays behind allowing gunite to bleed through.
    THis may be due to bad plaster or just the years have come : The plaster start to pop off or hollow spots ex: u know it's hollow because when u walk on it, it feels mushy.
    Houston TX
    Thanks for the info, Gutierrez!! Looks like I'm OK for now.
Closed Thread
