I am in S. Texas - same problem.
I've often thought about what adding dry ice the pool water would do to it. It is certainly cold enough, but I can't find anything that tells me what (if any) chemical changes it might make to the water.
Any ideas?
Any ideas?
I live 20 minutes south of SA. Next week is going to get to 106 here so watch out!
might raise the TA and/or lower the pH. The carbon dixoide will dissovle in the water and form carbonic acid which is part of the TA buffer system and also has an impact on pHOriginally Posted by estonb
Here is an idea. If you buy a hot tub air pump and plumb some pvc together with a horizontal pipe running about 10' along bottom of pool several holes drilled in it and an end cap you could cool the temp during the night possibly. I get this idea from a friend who has hooked up the same stuff to steel pipe running through his wood burning stove and the heated air then is blown into house with the hot tub pump which you can control the speed of.
Deleted as merchant has unfair business practices.
33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
Aqualuminator with Fountain -- Solar Pool Lights
Pool Pictures at the link below
http://community.webshots.com/album/548241672nKeuyR
Not sure it would work but it is cheaper atOriginally Posted by gwrace1
http://www.poolcooler.com
Tom
I would have thought that a couple of cooling fans run at night over the pool surface to help evaporate the water would work.
Advantages are:
1. Don't need to run the pool pump.
2. The air temps at night are cooler.
3. The higher water temperature helps to increase the evaporative effect.
Just make sure that the fans are connected through a GFCI outlet.
Hope this helps.
Pat
Ya'll may have missed this thread about evaporative cooling....it works.
http://www.poolforum.com/pf2/showthread.php?t=4243
I just ordered 2 of these devices. I hope they work as advertised. I will post back my experience with them and let you know if they work or are bogus.Originally Posted by tclemmer
I received the pool cooling devices today. I will try to install them tonight and see what they do. I will let you know. BTW-if you buy 2, the S&H is free.
