Results 1 to 10 of 14
Thread: Yikes! Small pile of gravel in pool
    jenpen400 Guest
    Default Re: Yikes! Small pile of gravel in pool
    I'd be really carefull if you try the vac hose without anything on it. I only have a .75 hp 2 speed above ground pump and on high there is no way I could pull the vac plate off of the skimmer without turning the pump off. If the end of the hose got a hold of you or the liner I would be afraid you might get hurt or damage the pool. Let the boys clean it up.
    jennifer
    Rocket City, AL, USA.
    If you don't make the boys get it, why not try a Venturi vac system? I got one at Lowe's last year for about $20.
    Tried the venturi vac, as I said, no go. One has snorkeling equip, I'll make him go back in there and clean it up. Thought I might have missed something simple - other than that. It's like taking out the garbage, they make most of it, but its like pulling teeth to get it taken out! Thanks all
    Doh! Somehow I totally missed that you tried that.
    Honesdale PA
    Don't know what a venturi vac is, and maybe I'm missing something, but how about a plain old vacuum brush? Hose hooks to the skimmer. I likewise wouldn't go against a liner with the end of a hose.
    Aranon is offline Registered+ Thread Analyst Aranon 0
    I took the vacuum head off my suction vac and used waterproof tape to tape my light extension pole (goes to leaf skimmer) to hose and I use the hose at an angle to go around the edges and pick up sand that seems to lie where my cove starts. My yard around the pools is sand right now and my three boys get a lot of it in the pool. The Vacuum brush does not seem to want to pick it up against the wall but just the hose does great. Attaching it to the aluminum pipe makes it easy to go around the pool and pick up all the sand.
    Aranon
    The vac brush would not pick it up either - I'm guessing its something to do with the edges of the brush preventing enough concentrated suction to lift the grains (biguns) - Anyways, we had the snorkler use his equipment and pick it out.....
    Venturi vac (attachment to extension pole and garden hose, water forces the waste up into filter "sock")
