Either one is fine, I prefer acid since it is cheaper and a bit more efficient but is it not as nice to work with as dry acid. Your choice.Originally Posted by no1ford
Ok-well I still have some ph minus from opening-so I will try that first. I added 1/2 cup to start for an 18x48 pool. I have read that if the ph gets to low it can harm the liner-so I a liitle hesitant. I will re-check in two hours. On average how long does it take for Alk to lower-is this another long process? Should I keep my filter running?
A couple more questions:
And I am still unclear about aeration.
One alk is adjusted do I add borax to raise ph back.
Can I continue to add my bleach as normal during this process?
I really appreciate your help. By next season I should be a pro!!
Ph-7.2
Alk-200
Had a few kids jump in the pool to move it around. Should I add more ph minus or let it circulate overnight?
Hope this helps.Originally Posted by no1ford
Great thanks! I will continue to "disturb" my water!![]()
Should I leave the pump running the whole time?
you have been a huge help to me through this! Can't thank you enough!
That's what this forum is all about.Originally Posted by no1ford
Todays numbers-
CL- 5-10
ph- 7.5
alk-220
cya-30
I have added ph minus for 4 days now and my ph and alk will not drop! I have had a ton of kids in there to help aerate too! Is this another long process? should I go buy alk minus from Walmart?
Please help! My water is back to being cloudy again!
Also my test kit says to test cya 2 times per summer--sound right?
You have to lower your ph down to 7 or 7.2, then aerate the water. As the alk goes down, your ph will rise. You must continue to add acid to bring down the ph to 7 - 7.2 and then aerate again. You do this process untill your alk is between 80 and 120. Muriatic acid works for ph or the dry acid for ph down. Not alk reducer. Hope this helps.
Northeast PA
