Thread: When is the best time to run your pump... and for how long
    Lafayette, La
    Default When is the best time to run your pump... and for how long
    My husband and I can not seem to agree as to how long the pump needs to run and what time of the day is best to do it. I have a 12,000 gallon fiberglass pool in South Louisiana temps are mid 90's ervery day-very little rain and pool is in full sun. I switched to bleach this spring when I discovered I had a CYA level over 150- even with partial emptying ( at least 8 times) it is still around 135- this means that I add bleach- a lot at night and some during the day to keep my cl level around 7-10. My pool water is crystal clear- PH 7.4 TA- 150 Cal- 250
    Since I am adding the majority of bleach at around 9PM I have been running the pump 24/7. My husband would like to run it 10-12 hr perday. When would be the best time to run pump?
    Thanks for any help. I have enjoyed reading all posts- I check in a couple of times a day. You all are great!
    Barstow, CA.
    Default Re: When is the best time to run your pump... and for how long
    I also have a 12000 gallon FB pool. I run my pump 3 times a day: from 8pm to midnight, then from 5am to 7am, then from noon to 2 pm. 8 hrs total.
    I add bleach at 8pm, letting it work without the sun to use it up. I check chemistry in the am before work (thus the early start time), and I run the third cycle from noon to 2pm just to move the water around under the solar cover.
    I live in the Mojave Desert, it's been over 110 here lately, the pool is in full sun from 8am to 5pm.
    My pool is crystal, liquid glass clear.
    Temp = 88
    FC = 5
    CC = 0
    CYA = 60
    PH = 7.8 (too high, adding acid tomorrow)
    TA = 120
    Are you working on an algae kill? Why the 7-10 FC level? Anywho, we run ours on a timer, 11:15am-8pm (sun goes around house at 7 so we add chlorine from 7-8pm)
    mas985's Avatar
    Pleasanton, CA
    Most pools require 1 to 2 turnovers per day for proper filtration. Here is a thread on how to calculate turnover.
    http://www.poolforum.com/pf2/showthread.php?t=3022
    Mark
    Lafayette, La
    Not working on an algae kill- My CYA is high (135) so in order to maintain balance I have to run a high chlorine. Based on Bens best calculations I need to keep my Free chlorine between 8-15 ppm. It is working - my pool is crystal clear!
  1. Long Time Lurker, First Time Poster
    By MikeD in forum Dealing with Algae & Slime
    Last Post: 08-04-2012, 09:26 AM
  2. Long time forum reader
    By steve52 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-29-2012, 03:27 PM
  3. Long time reader, first time author
    By j_stewart89 in forum General Interest
    Last Post: 04-06-2012, 07:05 PM
  4. The pump is dead, long live the pump!
    By maryberrye in forum Above-Ground Pool Construction & Repair
    Last Post: 07-05-2011, 01:38 PM
  5. How long to run your pump
    By Cal_Newbie in forum Above-Ground Pool Construction & Repair
    Last Post: 04-03-2007, 08:05 PM
