Re: Pump Died? Help with Autopsy
Thanks for all the input. I think that Pat has something.
I disassembled the hoses to the pump and checked to make sure there wasn't something clogging.
I took apart the housing between the filter and the motor and then plugged it in for a second to see if the empeller was turning. It looked fine. So I reconnected everything.
There wasn't much in the filter basket on the pump nor in the skimmer basket but...
my skimmer basket has a rod across the top which prevents me from sticking the filter bag inside so I had tried it on the outside of the basket. There was a knob of goop on the underside of the basket which may have been plugging the outlet hose of the skimmer.
Anyway...when I reconnected everything and plugged it back in - voila! it works. Now I can return that $230.00 pump I bought today just in case.
Waste, thanks for the offer of a guided autopsy. If I ever really do need it, I'll holler.
CoffeeBean
