Results 1 to 10 of 12
Thread: Pump Died? Help with Autopsy
    western Washington state
    Default Re: Pump Died? Help with Autopsy
    Thanks for all the input. I think that Pat has something.
    I disassembled the hoses to the pump and checked to make sure there wasn't something clogging.
    I took apart the housing between the filter and the motor and then plugged it in for a second to see if the empeller was turning. It looked fine. So I reconnected everything.
    There wasn't much in the filter basket on the pump nor in the skimmer basket but...
    my skimmer basket has a rod across the top which prevents me from sticking the filter bag inside so I had tried it on the outside of the basket. There was a knob of goop on the underside of the basket which may have been plugging the outlet hose of the skimmer.
    Anyway...when I reconnected everything and plugged it back in - voila! it works. Now I can return that $230.00 pump I bought today just in case.
    Waste, thanks for the offer of a guided autopsy. If I ever really do need it, I'll holler.
    CoffeeBean
    Talking Re: Pump Died? Help with Autopsy
    Glad to hear it's all set !!
    Poolguy,
    Has your pump been revived? I feel badly for you that your outcome wasn't as simple - or cheap - as mine.
    CoffeeBean
    West Texas
    Quote Originally Posted by CoffeeBean
    Poolguy,
    CoffeeBean
    Nah, I have to order an empeller Monday. I found all the seals at Leslies but no luck on the empeller. So it will probaly be Wed before she's up and running again. Thanks for asking.
    cgc2 is offline ** No working email address ** cgc2 0
    Quote Originally Posted by ThePoolGuy
    Im just currious...how old is your pump/motor, and how much does an impeller cost ??
    West Texas
    Quote Originally Posted by cgc2
    I'm not sure how old the pump/pool is. The house is only 4 years old but the pool was built at a later time. So it's only a few years old at best. As for the cost of the imepeller, they retail for around 20.00 - 30.00 bux depending on which one I got but I can order them at cost instead. I only went to Leslies to see if I could fix the pool Saturday instead of waiting on the parts.
    I see people referring to Leslies on the Forum. I'm surmising it's a pool supply store. Is it a local thing?
    I'm out of CYA reagent and have been waiting on Ben's reorder for several weeks now. I tried finding Taylor reagents at our two local stores but they have what I term "kiddie" kits and looked at me strangely when I asked about Taylor. Is Leslie's on the net?
    CoffeeBean
