CYA=Cyanuric Acid=IsoCyanuric Acid=Stabilizer=Conditioner.
All the same thing.
All the same thing.
"Looking for Minimal Maintenance"
Aren't we all!![]()
FWIW, The PoolPilot Total control SWG does control PH as well. Mine''s not installed yet so I can't speak to it's effectiveness but it also has the digital controller for the SWG so there's not much "dialing in". We got it explicitly for the low pool maintenence.
But you still have to add salt and refill the acid tank!Originally Posted by pcgeek
AND you still have to balance your other water parameters manually.
I only have to add a pint to a pint and a half of acid every three weeks with my SWG but your milage may vary.
So, you only have to add salt if you get splash-out, etc given that it's not consumed. The acid tank is 15gal (diluted 4:1) so you're not going to be refilling it all that often. The other water parameters tend to move a LOT less frequently than CL and PH which should significantly reduce the attention you need to pay to the pool on an ongoing basis.
Originally Posted by CarlD
lol
being a new pool owner...I'm really beginning to think that minimal maintenance is achieved thru staying on top of your pool. Check your water often, vacuum regularly (by hand or automatic machine) and run your filter.
Keeping a pool clean and chemicals in check seems to be far less work than what my relatives and neighbors do after they let it go a bit. Sure am glad I found this site
take care,
dan
