Results 1 to 10 of 40
Thread: Could this be algae or dirt/pollen?
    joliecharlie is offline ** No working email address ** Thread Analyst joliecharlie 0
    Pinehurst, North Carolina
    Default Re: Could this be algae or dirt/pollen?
    As I posted... my chlorine reading was 15ppm last night
    No CC ever
    I checked this morning and it is still 15 ppm!
    So maybe I have over reacted but this stuff sure looks funky. It is like a red dust, just like the photos at the beginning of the this thread.
    It dissipates into a cloud when brushed. There is just a little bit of it this morning.
    We have lost CYA via dumping excess water due to heavy rains and backflushing. We normally keep the CYA higher because we have full sun exposure ALL day and cannot keep chlorine. Keeping it higher has pretty much solved that problem. It may not work for everyone, but it works for our pool.
    Sorry - for some reason, I just didn't see where you had posted your chlorine reading. I'm gonna let ChemGeek help you with this. I'm actually out of town and just popping on to the forum on a laptop. Getting ready to head back to Charleston in a little bit. ChemGeek or somebody else will be around this afternoon and can give you some help. Good luck.
    Well, if your chlorine is holding, then it isn't breaking anything more down and if the dust or algae or whatever it was is gone, then it is probably killed and filtered or broken down. If it was truly red (the pictures at the start of this forum look more green/yellow to me and that's more like mustard/yellow algae), then this could either be non-algae like dirt or could be a red algae (there is that type of algae, but it's usually not found in pools as far as I can tell).
    Anyway, it does sound like you've solved your "red dust" problem. On the CYA amount, I am surprised that 60 ppm CYA makes that much of a difference compared to 30 ppm CYA. In theory, it would only increase the half-life of chlorine (in direct noontime sun) from around 6 hours to 7 hours which isn't that much of a difference. Of course, whatever works for you is what is best.
    Let your chlorine drop to "normal" levels but keep it as suggested at around 6 ppm FC or so minimum (at your current 40-50 ppm CYA level) and see if this stuff returns. If it does, then you can try shocking to higher levels (20-25 ppm) as I mentioned in my earlier post.
    Richard
    Richard[/QUOTE]
    Hi Richard,
    Just checked the chlorine after full day of sun and 80-85 degree weather here in NC.
    FC has dropped by 5ppm since this morning. (Remember it held stable overnight at 15ppm)
    Is it normal to lose that much chlorine in a day?
    That does seem a bit high for a drop. Losing half of the chlorine over a day is more typical -- so 15 ppm to 7-8 ppm would be more "normal". Then again, I could be wrong about those half-life numbers. They seem to be correct for most pools, but there's no arguing whatever it is that you are seeing in your pool. It's also not like you are in south Florida or the middle of summer. Maybe there is in fact some algae in your pool and it is growing more during the day and consuming more chlorine, but typically if it holds overnight then this means the algae is gone. Sorry I don't have a good answer for you.
    Richard
    OK, I've been thinking more about this and I believe you do still have a chlorine demand with this (presumed) algae. It's probably a demand of 1 ppm per 8 hours or maybe a little more. That would "seem" like the chlorine holds overnight, but if you lose half from the sun 15-->7.5 and then another 2 or more from chlorine demand from the algae, then that would get you to 5.
    So, I would suggest really hitting this algae with a lot of chlorine. Start with 30 ppm FC in the morning. If you are able to stick around and add more chlorine during mid-day, do that, otherwise add more when you get home at night. Keep this up until 1) there is no more visible red dust and 2) the chlorine holds solidly overnight (virtually no drop at all) and holds more during the day so it drops no more than half.
    If that works, then the question becomes how to keep this algae away ongoing. Though you could maintain a minimum of 6 ppm FC at 45 ppm CYA (or 8-9 ppm FC at 60 ppm CYA) which is what some others have found is required to keep away mustard/yellow algae, there is another way that might let you keep lower chlorine levels. See this thread for the use of 30-50 ppm Borates in the pool which act as an algaecide (as well as an additional pH buffer). The problem is that we don't know if this is a good algaecide specifically against mustard/yellow algae though it does inhibit a variety of different algae. Anyway, I just wanted to give you a long-term option that might help since this is a repeated problem for your pool that would require higher chlorine levels to keep away (even at 30 ppm CYA, you might have to keep a minimum of 5 ppm FC to keep away mustard/yellow algae instead of the normal 3.5 ppm FC mid-point recommendation).
    Richard
    Hi Richard,
    You are so kind to help me. I may have been unclear in the previous post about the loss I experienced. I started the day Sunday at 15ppm (it held overnight Saturday) and ended the day Sunday with 10ppm.. a 5ppm loss.
    I added Bleach last night to bring it to 18ppm ( I also put one trichlor puck in the skimmer)and checked this afternoon. The chlorine is 14.5ppm. It was not as hot today, but sunny almost all day. I added another 96oz of 6% bleach (usually gives me 3ppm rise) a little bit ago. I know when the CYA was about 60, I did not have as big a drop daily. You did a survey last summer and asked me for my numbers ( I don't remember them now)
    I am nearly positive this is some sort of dirt/pollen. It brushes away very easily, just the momentum of the water will disturb it. I cannot find anything on the walls or ladder. I have run my fingers under the ladder step and found nothing.
    I am reluctant to add more stuff to my pool because one of my 4 legged children drinks out of it! I hate to even use algaecide, so I am not too sure about the borate....although I realize if we had city water it would be the same thing or close to it.
    Mary Beth
