Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Switching to BBB. What do I do with these numbers?
FAQ
register
Results 1 to 10 of 17
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-26-2006
06:43 PM
#12
aylad
View Profile
View Forum Posts
SuperMod Emeritus
Burfle Ringer
Re: Switching to BBB. What do I do with these numbers?
If it will only test for Chlorine, then it's testing for total.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Looking for Minimal Maintenance
Compare Calcium and Sodium Hypochlorite
switching to saltwater
By mrsmatthews in forum Salt Generators (SWCG) & other Chlorine Feeders
15
Last Post:
05-08-2013,
06:36 PM
Switching from Ionization need Help
By wil804 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
3
Last Post:
07-09-2012,
10:14 AM
Switching from Chlorine to Salt
By kmmlangston in forum Salt Generators (SWCG) & other Chlorine Feeders
22
Last Post:
08-05-2010,
09:59 PM
Switching Pool to SWG
By jl1965 in forum Salt Generators (SWCG) & other Chlorine Feeders
1
Last Post:
06-12-2008,
10:51 PM
Switching to Bleach?
By JimSentry in forum Using Chlorine and Chlorinating Chemicals
13
Last Post:
07-13-2006,
11:57 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
