Results 1 to 10 of 19
Thread: Pool still green
Threaded View
  1. #17
    duraleigh Guest
    Default Re: Pool still green
    First of all, this forum wants to help clear your pool....that's the goal. That said, every single piece of advice we give is based on your test results.
    The problem is the test results are not consistent or accurate. This has been the biggest problem we've had. note my earlier post:
    Your pool has had some puzzling issues. My best guess is innaccurate testing methods.
    I have no idea how to help you test accurately and, if we recommend a regimen, that regimen is not very helpful if the test results don't make sense.
    The next time you test, post those results and we will all ASSUME those are accurate and base our suggestions on those results only....not anything previous....that's the only thing I can think of.
    PS - skip the "nuclear shock"...in fact, you would do well to skip the pool store's advice
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 11:25 AM
  5. green green pool
    By mr greenpool in forum Dealing with Algae & Slime
    Last Post: 07-09-2006, 02:04 PM
