Results 1 to 10 of 15
Thread: Green Pool during Stain Treatment
    mbar's Avatar
    Ashland, PA
    Default Re: Green Pool during Stain Treatment
    Sorry for your trouble. First question, did you add enough sequesterant for your pool size? It is always better to add more than enough versus not enough. Second, you may have some algae forming - with a cya of 50 you should not have chlorine under 3 - you need to keep it around 5. The ascorbic acid (vitamin c) will bring the chlorine down to 0, and will continue to bring chlorine down as long as there is ascorbic acid in the water - that's why you bring your chlorine down to 0 efore the stain treatment, because the ascorbic acid gets eaten by chlorine. The bringing the ph up to 7.8 is for trying to get the metals to stain the filter, he wants you to put a trichlor puck in the skimmer basket - this way when the high ph water hits the chorine puck, it makes the metal precipitate out of the water and land on the filter. I don't try to do this myself - I just add the sequesterant and keep my ph low for the first 2 weeks after a stain treatment, so that as I bring up my chlorine levels they are less likely to precipitate the metals. I also keep a chlorine puck in the skimmer. You don't want to put a chlorine puck in the skimmer if you have a cartridge filter - only a sand or DE.
    This is what I would do - make sure you have enough sequesterant in the water. Bring your ph down to 7.0 to 7.2. Put a trichlor puck in the skimmer basket and keep your pump running 24/7 (not if you have a cartridge). Add polyquat. Start to bring your chlorine up, and watch for stains (keeping the ph low will help not to stain) If you see stain forming, put more sequesterant in the water. Keep adding more and more chlorine - be consistant - don't let it fall lower than you had it , if you have it at 5 do not let it drop, add more to get it to 7, don't let it drop, keep doing this till you get up to shock levels.
    You may have algae, so you will have to get the chlorine up to shock levels, which for you will be 15ppms. It will be hard at first, because the chlorine will get eaten up by the ascorbic acid and the algae. Keep the filter running 24/7, backwash everyday, and if you have a sand filter add a cup of DE to the skimmer, or you can add a skimmer sock (or a cut leg from pantyhose). This will help filter out small particles. Keep us informed, and ask any questions you may have.
    Northeast PA
    Thanks for your reply. I put the recommended dose of Metal Free in and I thought I had enough, but perhaps it wasn't. I will add more. Your advice sounds good, so I will try as you say. Yes, I do have a sand filter. I have already added a whole bottle of Polyquat. Should I add more? How much and when? And one thing I don't quite understand. Why did the pool turn green right after adding chorine? Just coincidence?
    mbar's Avatar
    Ashland, PA
    You don't need anymore polyquat. Your water may have turned green when you had high ph and added high chlorine. The sequesterant probably kept the metals from falling out onto the surface of the pool. Just a chemical reaction - hopefully you don't have algae, but if you do the chlorine will kill it. The chlorine can also just be getting used up getting rid of the vitamin C. How does the water look today?
    Northeast PA
    It turned from green to crystal clear in about 8 hours! I dropped the pH and I think that made the difference. I also added some more metal out and am adding lots of bleach to bring the CL level up. Looks great now! Thanks for your help.
    Bobby C.
    Upstate, NY (Dutchess County)
    Quote Originally Posted by mbar
    So how does the metal actually "get out of the water" with this process? Does the sequesterant (I'm assuming Metal Free) make the metal "filterable"?
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    mbar's Avatar
    Ashland, PA
    Sorry, but the metal stays in the water. The sequestering agent bonds to the metal and keeps it from precipitating out. So far I know of no way that takes the metal out once and for all. That's why it is important to keep enough sequestering agent in your water at all times. I am still researching.
    Northeast PA
    Hmmm... can shocking force the iron out of the sequestering agent and back on the liner? That would really be bad...
    Loop-Loc Mesh cover
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    I understand this to mean that the high chlorine in the puck makes the metal precipitate and stain the DE in the filter, The backwashing would then flush the DE and the metal along with it, removing it from the pool.
    mbar's Avatar
    Ashland, PA
    leejp, yes shocking espeically with high ph will make metals that are not bound by sequestering agent precipitate out and stain the liner.
    haze1956,
    Yes, one way to get the metal out of the pool is to put a trichlor puck in the skimmer basket and raise your ph up to 7.8 - this will make metals fall out on the filter, which will then be backwashed out, therefore it will get the metal out of the water - the only thing it could also stain on the pool - that's why I like to use the method of sequestering the metals, but the metals do not get filtered out. I also like to put a puck in the skimmer when I am first bringing my chorine up after a stain treatment to make sure if I don't have enough sequestering agent the stain will hopefully fall out on the filter first. I do not raise my ph when doing this - I keep it at about 7.2.
    Northeast PA
    nj, usa.
    Hi Marie,
    I'm curious to understand how this metal removal process works.
    Is it high PH or the high chlorine of the Trichlor that makes the metals precipitate?
    And if the filter fails to catch the metals and they return to the pool, would they stain the liner or would they go back into solution as the filter water dilutes in the low chorine, low PH, pool water?
