Thread: Cloudy water
    San Leon, Texas, USA.
    Unhappy Cloudy water
    I cant test for FC CC TC, but I hope someone can ease my mind.My pool is always crystal clear using this site.Last eekend had lots of traffic in my pool.Then we had 3 days of hard rain and I couldnt care for it properly.I got about 4 inches of rain in my pool.Now my water is kind of cloudy. Not bad , just not as clear. My numbers are, TC 5 , PH 7.4, ALK 120, CYA40-50, NO hardness, 4x18 round vinyl. Am I correct in thinking I have excess CC, with these Numbers. There is no chlorine smell tho, and no eye burn. Thanks so much. Love this site. Gladys
    duraleigh Guest
    Default Re: Cloudy water
    Gladys,
    That's a little puzzling but probably a cheap, easy fix. I would shock the pool to 15ppm in the evening....test and add accurately.
    Tomorrow AM, If your Cl has dropped more than a point or so, I'd say chloramines was your issue. The pool should clear and you'll be all set.
    I suggest Ben's kit. It allows you to test your Cl with accuracy and will test for CC's....sounds like you could make good use of it...you have a very good understanding of your pool water but you need a kit to help you measure what you're doing.
    Thanks, I will shock tonight and see if that solves the problem.
