Results 1 to 10 of 11
Thread: SWG----Want one next year!!!!
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    Default Re: SWG----Want one next year!!!!
    graciec, I just finished my SWC install last weekend. It's really isn't very complicated. Someone who has worked with PVC before and has decent electrical skills can do it.
    graciec is offline Registered+ Thread Analyst graciec 0
    I will try to post a photo to see if you can tell me where it would go[ i have an idea]........I am worried that I don't have enough pipe 'space' for the generator.
    I don't have a seperate spa......
    Houston.
    Here is a picture of mine that I posted on gardenweb. It's a bit hard to see, but the water goes through the filter (on right) then the heater (black on left), and then through the chlorine cell. I was trying to explain to someone how my system has a manual valve and a one way check valve to allow some water from "pool mode" to be returned into the spa and then over the spillway to circulate the spa with the pool water.
    >>Here's a pic of my equipment. The light blue arrows point to the valves the aqualogic turns. On the left, after the chlorinator cell is the return side where the blue valve adjusts to 100% pool return or 100% spa return. With the valve turned to 100% pool return, the water flows down the left side toward the white arrow. The white arrow is pointing to the manual valve on the pool return side that is adjusted to allow some (maybe 10-20%) of the water to flow across the one way check valve (yellow arrow) and then down the spa side return with the green arrow.
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    Smile Re: SWG----Want one next year!!!!
    I Am going to put this in my favorites!
    What a space age looking heater! who makes that?
    Is it hard to post a picture? We have a digital camera.
    Is there a process or program that's easy to use? thanks!
    Berwyn, PA
    Sta-Rite - I have one, it's great. My kids refer to it as "R2D2."
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    bbb is offline Registered+ Thread Analyst bbb 0
    Is is mandatory to plumb in a bag of Doritos as a filter bypass? Is this where you vacuum to waste?
    bbb = bleach, borax, & baking soda
    Houston.
    I always wondered what that dorito bag was for. Vacuuming to waste. Now I know.
    Putting in an image is not hard. Just realize that it takes longer to download the forum thread so its probably not a good thing to do unless someone is really looking for a picture of something.
    The picture is hosted on another machine. I use the advanced editor and there is a button for including an image that asks for the URL to the picture.
    Yep, that's a Sta-Rite. So far it's been a great heater. Only 6 months old, so I'm knocking on wood now that I've said something about it.
    Robert
  1. Replies: 3
    Last Post: 05-21-2013, 03:16 PM
  2. first results of year, re-filled pool end of last year
    By vinouspleasure in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2012, 04:54 PM
  3. 1st year SWG help
    By cheesemaster in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-01-2007, 03:52 PM
  4. first year on BBB
    By nisqu in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-10-2007, 10:18 AM
  5. Opening - Last year, a nightmare. This year, perfect...??
    By bcb1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-30-2006, 10:01 AM
