Re: Solar Reels.
Re: Solar Reels.
Try them now. They should be good now.
Thanks.
Aranon
Re: Solar Reels.
So no one knows anything about either of these reels?
Re: Solar Reels.
If you use your solar cover alot.........reels are as handy as a pocket on a shirt. that is, IF you need your water warmed??????????? Most people don't need one, or want to deal with the hastle of putting on and taking off.
consider what is best......then go from there
Re: Solar Reels.
Tracey,
To clear up some things about solar covers:
1. They are more useful than you think, they also keep your water in the pool rather than allowing it to evaporate - VERY important for those that have a limited water supply. I'd spend 100 on a solar cover any day since I'd save over 200 on trucking in water over the course of one summer.
2. They help against heat loss over night, also important if you like to go for an AM swim.
3. They don't heat the pool as much as you think, but in some parts, they are required just to get the pool to a comfy temperature.
Re: Solar Reels.
SO sorry MATT,
don't know where you live, but here, most people don't use them
to each their own dependant on where in the states they live
SORRY
Re: Solar Reels.
I live in Texas but my pool is under a huge oak tree with shade cloth over it to keep the oak leaves and acorns out of the pool, so I have almost 90 percent shade. Even though it gets hot here in Texas its at the end of June and we are having 60-70 degree nights. I have 9 solar panels to heat the pool but we have found that we lose about 6 to eight degrees if we leave the solar cover off at night. We don't use it to heat the pool in the day, but to keep the heat in during the night. Also it sure helps to keep the water from evaporating which is actually keeping the heat in the pool since evaporation is a form of cooling.
My solar bubble blanket is very heavy and add a little water on it and you can barely even move it until you get it all in the pool. It is such a hassle and hard work to get the cover into the pool to cover it. I want to get a good reel that will last. I assumed a lot of people would use covers, but I guess I assumed wrong. It is a must for us. And I did go for a swim this morning with the water at 89 degrees and man did it feel good at AM this morning. The good thing about our solar panels is that when it gets hotter this summer I can turn them on at night and cool the pool. But until then I need the blanket. Thanks for any info on a good reel from anyone that knows about them.
Aranon
