Thread: Hardness
    Sunny32504 is offline ** No working email address ** Sunny32504 0
    dallas,texas
    Default Hardness
    First let me start out that I don't use strip testing. Buttttt I received these free strips from pool time I think and decided to try them. Anyways it says my hardness is "high" which shows to be 1000 at the most. Should I be concerned? I have a vinyl liner pool 33' ROund.
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Hardness
    First, the strips are testing total hardness which is going to be higher than calcium hardness!
    Second, the strips are just not as precise as a drop based kit. What is your calcium hardness reading from a drop based kit. If it is very high then you might run the risk of cloudy water or scaling.
