Thread: Hardness
    Sunny32504 is offline ** No working email address ** Sunny32504 0
    dallas,texas
    Default Hardness
    First let me start out that I don't use strip testing. Buttttt I received these free strips from pool time I think and decided to try them. Anyways it says my hardness is "high" which shows to be 1000 at the most. Should I be concerned? I have a vinyl liner pool 33' ROund.
    Default Re: Hardness
    First, the strips are testing total hardness which is going to be higher than calcium hardness!
    Second, the strips are just not as precise as a drop based kit. What is your calcium hardness reading from a drop based kit. If it is very high then you might run the risk of cloudy water or scaling.
  1. calcium hardness
    By walker1 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-08-2012, 11:49 PM
  2. What is hardness?
    By jerome in forum Dealing with Alkalinity and Calcium
    Last Post: 05-08-2012, 12:45 PM
  3. zero hardness
    By poolgal in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-01-2008, 02:54 AM
  4. Hardness
    By Lil Bit in forum Dealing with Alkalinity and Calcium
    Last Post: 08-16-2006, 10:25 AM
  5. Hardness
    By Lil Bit in forum Pool Chemicals & Pool Water Problems
