I add salt whenever my salt level drops below about 2800-3000 ppm. Normal maintenance for a SWG. I have a leak in my spa that the builder hasn't fixed yet so I am having to add salt a bit more often than normally.
I've had staining from solar salt crystals (Morton...99.5% pure) too Evan. The first or second year I just dumped a couple bags in several spots without moving them around. The old liner was faded so it was pretty apparent but lightened over time. Before the forum crashed, I think Pat posted he had staining as well and uses salt blocks.
Next time you might try moving around with your brush in several places.
This is the first time it has ever happened....tried a vitamin c on it and it cleared about a 1 foot square area in about 2-3 minutes. This pretty much confirms that it is iron! Guess I have a project for this weekend now.
I pour the salt in and I do brush afterward. If you check around the forum you will find that I am a firm believer in brushing after adding any chemical to help distirbute it!I like to dumpt the salt on the ledge since it is in the direct flow of the return and this helps to move it around the pool also. Never had this happen with Morten Pellets, Diamond Crystal Sun Gems solar, Morton Pool or Diamond Crystal Pool!
Evan, since I think the same thing just happened to me to with "pool store salt", I just added some sequestrant right away. I didn't mess with the PH 'cause I'm not brave enough for that stuff yet. I did brush the stains every day and one day they seemed to be gone. I think the trick is to do something right away before it gets set in "stone".
Now, I'll be extra vigilant when adding salt or new water and make sure I have sequestrant handy. Yeeesh...it seems strange to have to sequester a pool instead of a jury.![]()
Karin
11000 gal Gunite pool/spa combo resurfaced 3-2006 with Diamond Brite
1 HP MaxE-Flo pump
Sta-Rite 150sq ft cartridge filter
Aqua Rite Salt Chlorinator
Vintage (ancient) Kreepy Krawley Cleaner
Heat Pump
Well, I got rid of the stains!...lowered the output on my SWG a few days ago so my FC was 1 ppm then I dropped the pH to 7.0, and since the staining was localized, I poured a bottle of 500 mg Vitamin C tablets into a sock and just ran it over the stained areas and watched them disappear. I then hit the pool with a good dose of sequestant and am running the filter and have turned up the SWG output a bit. Gonna recheck the pH tomoroow and slowly get that back up along with the FC....so far so good. I am now a happy camper!
yeah!!!, I am soooo happy!
Northeast PA
