Thread: Which water to fill with - softened or reg
    duraleigh Guest
    Default Re: Which water to fill with - softened or reg
    SoCal,
    That's a pretty easy one....use the soft water..no doubt. Do you have any idea as to the source of the Calcium. Normally, it should be stable and I see you're not using Cal Hypo....I can't imagine how it's getting in there. Anyway, use that CH=20 water...as much of it as you want but probably not less than 60% of your total pool water. That'll get you down around 250ppm which many folks think is ideal.
    The rest of your tests look dead on the money (nice work!) and, yes, it's always helpful to see test results even if they're not pertinent.
    the only problem would be is can your water softener keep up while filling the pool ? Usually they regenerate after a certain # of gallons have passed.
    Mesa, AZ
    normally Calcium rises slowly due to the fact that calcium does not evaporate and the make-up water contains calcium. Soft water for make-up water is a good idea to minimize the creep, but can drive your salt level up.
    I tested a neighbor's pool for salt the other day and he was at 800ppm merely by using soft water for make-up. He seems to get about 800 gallons per re-charge on his softener
    Saint Cloud, FL
    I don't understand the logic in that the salt level should go up when adding softened water. There should be litle to no salt coming from the water softener. If you do, then you have a problem with the softener that needs to be addressed. I have never had that experience in the 8 years of running a SWCG.
    My two cents.
    Pat
