Results 1 to 9 of 9
Thread: SWG and Bleach
    Crowley, TX
    Default SWG and Bleach
    I am sure this is on the forum somewhere...just have not been able to find it.
    My pool is inground, SWG, and blue pebble tec. I was thinking about, if it is advantageous, supplementing some bleach for chlorine and decreasing the SWG chlorinating % to maybe increase the life of the salt cell and reduce the number of hours the pump is running. Would the bleach harm the color of my pebble tec surface? Is this a bad idea?
    I am running my pump more hours this year due to a high phosphate problem. Something is getting in my pool and causing high phosphates (3rd time since March I have had this problem). So, I have been running my pump longer to keep the chlorine higher and to treat the phosphate issues (PhosFree). It has been expensive all the way around. Any assistance would be greatly appreciated. I know how to treat the phosphates...just not sure what is getting in my pool to cause the problem. Luckily, the water is very clear and I have had no algae.
    Thanks,
    Mike
    Ormond by the Sea, FL
    Default Re: SWG and Bleach
    Hi Mike, I too am battling high phosphates. Apparently our little city had some water issues and dumped phosphates into the city's water supply. Meanwhile I've been merrily adding this phosphate enriched brew to my pool....like I'm planning an algae farm. Yeeesh....
    I have used regular household bleach as a "shock" treatment now and then instead of using my "super chlorinate" feature on my SWCG. I too heard that it saves the life of the cell.
    I have a Cool Blue Diamond Bright finish and sometimes I think that the bleach may have caused some whitish streaks on the finish near the bottom of the pool...that or maybe the salt additions did even though I try to stir it up and brush it toward the main drain.
    I am planning on helping out our nations GNP and buying some sequestrants and algaecides as preventative measures this summer. (I think we have iron in our water supply and I know algae lurks everywhere in Florida...)
    If anyone has low cost sources for these items or good generics, please pass them on. I know chlorine will kill any problems, but I tend to get too worked up and wake up in a cold sweat at night if I suspect I have algae multiplying on the other side of my sliding glass doors...
    Karin
    11000 gal Gunite pool/spa combo resurfaced 3-2006 with Diamond Brite
    1 HP MaxE-Flo pump
    Sta-Rite 150sq ft cartridge filter
    Aqua Rite Salt Chlorinator
    Vintage (ancient) Kreepy Krawley Cleaner
    Heat Pump
    waterbear's Avatar
    St. Augustine, Fl
    First queston to both of you....do you have algae in your pool? If you don't then don't worry about the phosphate levels in your water. I have about 1000ppb phosphate and have yet to see an algae bloom in my water ( and yes, Karin, I live in Florida....one block from the atlantic ocean! Most of north and central Florida has high phospahtes in the water...they mine the stuff in this state!) nor have I ever needed to shock since my SWG went online last novebmer (based on never have tested CC over .5 ppm).
    If you have an algae problem AND phosphates have been determined to be the limiting factor in algae growth then a phosphate remover would be the way to go...otherwise you are just wasting money!
    The BEST algecide is chlorine....end of discussion. Polyquat can be useful at times but chlorine is your first line of attack against algae.
    If yo do need to shock then using bleach instead of using the superchlorinate setting will:
    1. be more effective since you are putting the chlorine in all at once
    2. prolong the life of your cell.
    I see no advantage to shortening your pump run time and using bleach....sort of defeats the purpose of having a SWG.
    Your water might test high in phosphates...if you don't have algae, so what? If it ain't broken don't try and fix it! One other note...most metal sequesterants will raise your phosphate levels since they are based on derivatives of phosphonic acid! Nitrates are just as important as phosphates as a source of algae food (perhaps even more so) but no one really mentions them...the reason is there is no stuff in a bottle you can buy to lower the nitrate levels in your pool! Pool stores make money by selling you stuff that you don't reallly need! I know....I work in one!
    Crowley, TX
    Thanks for the comments. The answer to one of your questions is no, I do not have algae. I run my pump about 10-12 hours a day at 85% chlorination (summer only of course). The temps here are averaging mid-90s to 100 most days in the summer. In fact...knock on wood...I have never had algae (pool built 15 months ago). The water is very clear and looks great except for the milkiness the PhosFree causes for a few days after treating the water. I tested the water this morning and it is around 1000 on the phosphate test. Was 2500 10 days or so ago. I am sick of messing with it and after this round of tests I think I will follow your advice and not worry about it. It is kind of funny that no one really mentions phosphates anywere in the stores unless you ask.
    Thanks again and have a great holiday.
    Mike
    Crowley, TX
    OK...Waterbear...a second view of your posting has sparked a new question. Is Jack's the Purple Stuff something that can add phosphates to a pool? That is the only stuff I am putting in my pool this year that is different than last year and it is a metal sequesterant. I believe it has phosphonic acid in it. Would that be enough to cause problems? I use it as a scale preventative every week per the instructions. Please let me know if you have any knowledge regarding this product.
    Thanks,
    Mike
    Crowley, TX
    Karin, you mentioned you might use a metal sequesterant. I have used Jack's Purple Stuff which is good stuff except I have verified now that is has phosphonic acid which is probably why I continuously have high phosphates (been using the stuff weekly since March). I will cease using it today. Natural Chemistry has some stuff called "Metal Free", I think, and it is phosphate free per the bottle label. Good luck and listen to Waterbear.
    Mike
