Thread: Idea for test kit
    mbar's Avatar
    Ashland, PA
    Default Idea for test kit
    I was thinking it would be nice to have a copy of the "Best Guess Chart" put on the pool test kit case where the rest of the instructions are. I copied it and taped it on the inside of mine with clear packing tape, so I can have it handy to look at.
    Northeast PA
    Default Re: Idea for test kit
    My home office (and PC) are right by the deck--even a sliding door. I keep the B/G table on the back of the office door where I can see it from the PC
    Tennessee
    Printed one and taped to the underside of my kit top. Also put a doseing chart made from bleach calc. I have made a few changes in doseing from what bleach calc spit out and wrote there as well. I also have a chart I set up for results and treatment log in my kit as well.
    Later
    Default Re: Idea for test kit-Where is the 'best guess chart'???
    Can someone tell me where to find this 'best guess chart' that I've been reading about??
    I tried a search for 'best guess chart' and was unable to find this chart that people are referring to.
    Thanks!!
    IL.
    Quote Originally Posted by human
    Thanks!!
    http://www.poolforum.com/pf2/showthread.php?t=365
    You're Welcome
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    Medvamp- where in TN are you? I am in N GA, about 5 minutes from Chattanooga.
  1. No idea where leak is coming from
    By gailh in forum In-Ground Pool Construction and Repair
    Last Post: 05-30-2013, 05:56 PM
  2. Old Pool, New Idea
    By FishTale in forum --cleanup--
    Last Post: 10-16-2012, 09:00 PM
  3. No idea what I'm doing!!
    By sadiesue517 in forum Intex-type Pool Setup & Operations
    Last Post: 07-03-2012, 08:34 PM
  4. Urg. I have no idea what to with this.
    By awhite6455 in forum Pool Electronics
    Last Post: 06-10-2012, 01:18 PM
