Re: Tonight I add salt to my non SWG above ground pool
The reason you want to add salt to a non SWCG pool is the same reason contact lens solution and IV's are saline solutions. If you put purified water into your eyes it "waters down" the salt in your eye's cells and causes them to sting, swell from excess water and sometimes burst. The cell becomes waterlogged because the low salt water is moving into the cell to water down the salty water that is naturally inside the cell. (This is known as hydrostatic pressure.) Contact lens saline solution is normally about 9000ppm because that's what feels good and it's approximately what's in your eyes. The closer your pool water gets to this point the less it stings your eyes and the more it tastes like sweat. Thus giving us a balance to work with..
The end result is that salty pool water is kinder to your body because there is a smaller differential between the saltiness of the water and the saltiness of your body.
Also, if you add salt to your pool you will increase the corrosiveness of your pool because NaCl contains chlorine.
22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
