Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 94
Thread: Tonight I add salt to my non SWG above ground pool
  1. #21
    Tennessee
    Default Re: Tonight I add salt to my non SWG above ground pool
    I hope this is not too geekey.
    The salinity of tears is around 9000 ppm dependant on body hydration. Body salinity is around 9000 ppm or isotonic at 0.9%. The ocean is around 0.35 % or 35000 ppm dependent on depth and temperature. Most salt used on the roads is Calcium Chloride witch is more corrosive than Sodium Chloride.
    The reason cars and boats have more problems are higher concretions and other metals involved.
    The reason it fells better is osmosis. Water is constantly trying to balance itself. You have less osmotic pressure at higher concretions of salt in your pool. Less water in to the skin means less flaking and itching. Think of it this way, you have a dead layer of skin at the surface the epidermis, as water enters these cells they swell and burst , when you get out of the pool these busted cells dry quickly, and cause itching and flaking. In salted water these cells have longer before they burst. The higher the salt levels to isotonic the less damage to the cell membrane.
    I haven’t salted my pool yet but I do plan to as I learn the BBB chem. method better.
    Later
    sailork is offline Registered+ Thread Analyst sailork 0
    Houston (Clear Lake area), TX
    Medvampire I would say you aren't being geeky enough. Shouldn't seawater be 3.5% not .35% by your own calculations?
    22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
  3. #23
    Tennessee
    Opps, Finger slipped, hate it when that happens.
    and dreams of a SWG
    Me too!
  4. #24
    Joliet
    If there's one thing I've learned from this site...it's that you measure and treat the problem you have. You don't just take stabs at what the problem may be...or toss a coin in a general direction in hopes that things will turn out grand.
    Could this be another case where measurements would be the best bet...to see both where we're starting from...and our target range.
    just wondering???
    dan
  5. #25
    Tennessee
    I am going to get my water tested and then add salt to around 1200 ppm and retest. I just haven’t found a good source of salt yet.
    Rocket City, AL, USA.
    Quote Originally Posted by sevver
    Well I am interested, how do you add it, just pour the bag of pellets in? Then get in and stir them around? What do you get, just water softener salt? I have an 8000 gallon pool, how much would a bag raise it approximately? Would a pool store be able to test for it?
    That is exactly what we did. To find out how much you need, just download the bleachcalc by mwsmith2 and enter your numbers. Don't forget to change your units to imperial instead of liters. This calculator will also help you with your BBB pool maintenance.
    A good source of water softener salt is Lowe's or Home Depot. I also believe that Wal-Mart sells it, too, as well as stores like Sam's and Costco. Try to get the purest salt you can find. In my case, we were able to find 99.8% pure salt.
  7. #27
    Morris, IL
    Ok, it says that if I add 80# of salt, the level will go up by almost 1200ppm for my 8000 gallon pool. I am thinking that if I start off with between 40# and 60# then it should be a good start. How long does it take for the salt to disolve? Do I have to be in there mixing it around?
  8. #28
    It took about 20 minutes to half an hour for my wife and I to dissolve two 40# bags. She had fun playing with the pellets, piling them up, moving them around with her feet, etc. The biggest thing was that we essentially were in the pool to help stir up the water. I'd recommend helping the salt dissolve.
    What I did was take a bag and open it in the middle of the pool, and spread it around a bit from the middle. We then shuffled it around with our feet until it was pretty much dissolved.
    1200ppm is about where we want to get to, so adding two bags will probably be perfect for your pool. If you aren't sure, then just get one bag and start with that. You can always add another later, but if you are happy with the results of just one bag, then there is no need. I did the same thing, I started with two bags, knowing that three or four would be what I ultimately will want to add. Two is nice, but I'll be adding one more sometime this week, and maybe one more after that.
    Just remember though that like CYA, the only way to get the salt back out of your pool is to drain and refill, so it's better to use less than you think you need than to overshoot your goal.
  9. #29
    So, does adding this salt have any effect on PH, TA, TC/FC? Is the luxury of having softer skin/hair and nicer feeling water going to result in any additional chemicals having to be added or any more work maintaining? I'm reading these posts and really tempted to try it, but if its going to be more maintc work.......(not that its so much now with BBB and a bit of leaf skimmer/vac work) But I AM the only one here doing the work, so less is better!
  10. #30
    IL.
    Quote Originally Posted by NWMNMom
    Nope
    Nope
    Dumping in the salt is the most work involved. After that, it's business as usual
  1. Salt for Above Ground
    By pkhydro in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-20-2013, 12:47 PM
  2. Help! Our new 30ft. above ground pool will be full tonight. What next?
    By Scarfie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-30-2011, 06:49 AM
  3. Salt system for in ground pool with liner.... Please help
    By pilot-werx in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-20-2011, 12:44 AM
  4. Salt water conversion(above ground pool)
    By lndknox in forum Above-Ground Pool Construction & Repair
    Last Post: 06-15-2011, 07:22 AM
  5. Tonight we hit 80 Degrees!
    By CarlD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-08-2008, 09:06 PM
