Results 1 to 10 of 44
Thread: Helllpp Fassssssssttttttt!
    Default Re: Helllpp Fassssssssttttttt!
    Oh thank you thank you thank you!!! This makes us feel much better. We are almost done with the foam and will at least lay the liner in there and fit it into the bead channel all the way around because it is supposed to rain tonight. It's already 8:00, so I doubt we'll get the liner fully installed. At least no high winds are coming!! Thanks again soooooooooooo much Dennis! You are the pool God! )
    Ok so we got all the styrofoam laid tonight. Did not get the liner in because I remembered it should not sit without water in it. So we're hoping to get the liner in tomorrow night and hopefully have water delivered on Wednesday. I'm too chicken to use my well. I decided against wall foam because I didn't want to wash down the interior walls (used pool and walls are a bit dirty) and I knew the foam wouldn't stick. So I skipped it. Also, didn't use a cove because the styrofoam covers the wall channel and any rough edges. Is this ok? As long as I use duct tape along the edges to join the styrofoam with the walls? We ended up putting a thin layer of sand down, then 1.5" high grade styrofoam. Am hoping my beaded liner will fit like a glove tomorrow night. Stay tuned............
    It all sounds good so far. Any chance of pics before the liner intall?
    Will you be following Matt's instructions for the beaded liner install?
    Remember that getting the bottom seams alligned correctly is the most important thing. The end to end (or maybe side to side) seams (or seam) and the seam that goes around the cove area. It must all fit the pool before you start the water.
    You should clean the walls as best possible. It will all show through your new liner, you will be much happier by spending a little more time and doing that.
    You should also consider installing the liner in direct sunlight. If you decide to try in the eve and it seems tight or like it does not want to fit, hold off for direct sun.
    Looking good, Dennis
    Quote Originally Posted by hrsdennis
    Ask and ye shall receive.........
    Now know that it's pitch black out there and I couldn't see through my camera lens so I was guessing where the pool was. That's why the pics are all crooked. LOL! Probably could see better in the daylight. I'll snap some tomorrow before we put the liner in. Yes, I saved Matt's directions. Will be referring to them for sure!
    Forgot to add that we're not done with the duct tape yet. The darkness chased us out of the pool before we were done. Will finish tomorrow.
    Great Job, and your pics were fine. Look forward to more.
    Dennis
    Looking good!!!
    You're doing a fantastic job.
    My recommendation is to use the cove material, having a 90 deg. corner is not the best of choices, the cove transitions the load (Weight of water) better and also gives you piece of mind that all that weight doesn't push through a small crack left between foam and wall, if there is even a small gap, the weight of the water will eventually push the liner in there as if it was saran wrap (with or without duct tape), so the cove would cover any such potential spots.
    Also, a cove gives a better transition to allow your kreepy crawley to climb the walls.
    With regards to the inweard lean of the straight wall - in my opinion, all oval pools should be built that way, I call it preloading, once all the water weight start to push, your wall WILL lean out some, so by preloading, your wall should become straight once the pool is filled.
