Thread: Design flow rate vs maximum flow rate...
    Default Design flow rate vs maximum flow rate...
    Hi All,
    I want to replace my existing 115v single speed pump to a 230V dual speed. My current 3.14sq ft sand filter (300lbs) states the design flow rate is 63gpm. My current pump flows 60gpm. I wanted to get the 1hp Pentair whisperflo but is has a high sf factor of 1.65 and flows 88gpm on high speed. Alternatively I could get the 1.5hp Superflo that flows 66gpm (using 50ft head for calc's).
    I have 2 -1.5" suction lines and 3 - 1.5" returns that can easily flow the 88gpm (or I can have 1 suction and 1 return if I close valves - or any combo in between) of the whisperflo but I am thinking it may beat up my sand filter. I was planning on upgrading to a DE filter later but not right now. Since my pool is only 15K gallons (give or take a few K) I am thinking I may be able to get the 1.5HP superflo which will give good turnover at low speed (at least 1 time/day) and won't shag my current sand filter.
    Any ideas?
    Thanks,
    J.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Design flow rate vs maximum flow rate...
    Why not the 1 HP uprated (3/4 HP full rated) Whisperflo two speed? You only need 31 GPM for an 8 hour turnover. At 50 ft of head, it has 70 GPM, half speed is 35 GPM. You will get an 8 hour turnover at low speed and 4 hour at high speed. Also, you will not need to change the power as it runs on 115v.
    One other thing, if it is a temporary situation, you could put in a slightly closed ball valve near the filter to increase the head loss. If you run the head up to 60 feet, the 1 HP uprated pump will flow only 60 GPM. Then when you get your new filter, remove the ball valve or open it up.
    Mark
    I thought the Whisperflo was perfect too (3/4HP) but really wanted to go to a 220V motor just because they tend to run a bit cooler. Wether or not it really makes a big difference, I don't know.
    Other option is the 1HP Superflo which will flow about 55GPM. I hope after all this research the Supeflo is a good pump I Would really consider the 3/4 110 Whisper if someone can convince me there is no major reason to go to 220V. Less wiring I have to do.
    Thanks!
    Joe
    Quote Originally Posted by cruzmisl
    How do you know how to figure ft head? I am trying to match a pump with a filter and can't read the proper GPM of the pump without knowing feet head...but I have no clue what this is.
    Is this where I admit I have a 18X36 Frankenpool? It will be vinyl lined, with no main drain when it's done. In the meantime, we are still trying to figure out the concrete work, pump, filter and all the other fun stuff that comes with a total/complete renovation.
    LA
    I can speak from experience...
    My old 1.5 hp pump sprung a leak so I replaced it with a 1 hp single speed Whisperflow pump. At that time I had a hayward sand filter rated at 62 gpm (3.xx sqft). The 1 hp Whisperflow easily outperformed my old 1.5 hp pump but it was to much for my sand filter. After a backwash the pressure would start at 22-25 psi. Also I would get a little sand in the pool so I replaced the sand and checked the laterals, everything was ok. My only guess is the 1 hp Whisperflow flowed to much for my little 62 gpm sand filter and that it was pushing sand through the laterals.
    This year I had the opportunity to replace the sand filter with a DE filter. Hindsight being 20/20 the sand filter was definately undersized for my 2" piping and 1 hp Whisperflow. The DE filter runs at 10-11 psi compared to the 22-35 psi the sand filter ran at. The only thing that changed was the filter!
    If I had it to do all over again the only thing I would change would be a 2 speed 1 hp whisperflow!
    For now you could buy the 2 speed 1 hp and just use the low speed (with your sand filter).
    Have you considered the 1hp 2 speed SuperPump from Hayward?
    Mine's been running into its 4th season now, mostly on low, and I use it with a 200# Hawyard sand filter with no problems on either low or high.
    It's a 220v pump and surely is PLENTY big enough for your pool and won't overwhelm your filter. I don't know Pentair, but I've never heard anything but good about them, I just know I'm DELIGHTED with my 2 spd SuperPump.
  1. Flow rate sensor?
    By henryb in forum Pool Electronics
    Last Post: 08-31-2013, 03:51 PM
  2. Pump mismatch with skimmer Flow Rate
    By jtran69 in forum Pool Equipment & Operations
    Last Post: 04-23-2013, 12:34 PM
  3. PVC Maximum Flow Rate?
    By catnip in forum Pool Equipment & Operations
    Last Post: 03-14-2007, 01:15 PM
  4. Sand filter design flow rate question
    By mbaldwin in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 05:42 AM
  5. Two-speed pump flow rate
    By sharkey21 in forum Pool Equipment & Operations
    Last Post: 05-03-2006, 09:18 PM
