Results 1 to 10 of 13
Thread: Changing over to BBB and a little scared
    Miami, Florida
    Unhappy Changing over to BBB and a little scared
    Hello all - I recently happened upon this site and am very intrigued with the BBB method as it appeals to my "all natural" sensibilities (and my wallet!) I would rather not use a service and you all remind me of the pool forum people on garden web, so helpful, enthusiastic and involved.
    Some background - builder completed my pool June 7 - fill was completed on June 8. Since then the pool guy from the builder has been coming out every other day (no weekends) trying to get my water balanced. For the first week he kept adding muriatic acid in increasing quantities to lower Ph. Finally he got tired of the pool, quote "kicking his butt" and last Friday he added ALOT of acid, liquid chlorine, and stabillizer and told me we could swim on Father's Day. We didn't because the Ph was on the floor and the chlorine was high per the pool store, didn't have a test kit then. We were away this past week on vacation and got back yesterday.
    Today he told me they will be "turning over the pool" to me on Thursday
    I'm petrified. I've been reading and printing out all the info I've seen here and would like to go the BBB route. It makes alot of sense except for a few things...
    ?1. How do you "switch over"? Do I just start using bleach, borax and baking soda on Thursday or is there a transition period?
    ?2. Is there an order to what you treat first, e.g. chlorine, then ph, then alk, when checking your water?
    He tells me that since my pool is in FULL sun (read - brutal!) in S. Florida all day long, it appears I burn through chlorine alot according to him, and my Ph tends to be somewhat erratic.
    I plan to order Ben's kit but I am going tonight to Walmart to buy a test kit for now and will post numbers tomorrow morning. I will thank you all in advance for your help as I count down to Thursday.
    Gracy
    Gracy
    16,725 gal gunite pool/1000 gal spa;exp agg finish; Jacuzzi 2 hp pump/Hayward cartridge filter/electric heater; Taylor K2006 Test Kit
    jnorris is offline Registered+ Thread Analyst jnorris 0
    Florence, SC
    Default Re: Changing over to BBB and a little scared
    Gracy,
    I'm not qualified to give you advice, as I just started running my own pool a couple of months ago. But just know that the people on this site are wonderful, and will lead you down the right path. It's not that hard to manage your own pool, and you will learn alot by just reading these boards. If you do as they say, and post your test results, they will give you all the answers you need!
    Judy
    Designated "pool girl" for 16 x 40 IG vinyl pool (installed in 2006) in S.C.
    Saint Cloud, FL
    Gracy,
    Welcome to the forum. We will be here to help you get started, so please ask questions as necessary.
    Go to the "Sticky" at the top of this forum, or the web page below from Watermom, and it will help you to get started.
    http://www.poolforum.com/pf2/showthread.php?t=1113
    Your pool builder will have settled the pool chemistry by Thursday, and should show you what to test with your test kit, and what to expect. You can follow the sequence you mention in Item #2, but again the pool builder will explain this. You mention the "brutal" sun in S Florida. I live in Central Florida and can empathise. Make sure you have about 40 - 50 ppm CYA in the pool as this will prevent the chlorine from evaporating too quickly.
    Keep us posted on your progress, let us have some test figures, and we will help you every we can.
    Enjoy your new pool and again welcome to the Poolforum family.
    Pat
    Talking Re: Changing over to BBB and a little scared
    Gracy, welcome to the forum! With a little patience and reading of both the forum and poolsolutions, in a month you'll have a better handle on pool chemistry than your builder!
    There is no 'transition time' to go with BBB (unless you've been sold Baquacil, in which case this one post won't be able to set you straight). BBB is not a 'system or set of chems to use together', like some of the kits sold by Bioguard etc, rather it is using chems that can be found in the grocery store that will do the same thing as the pool store chems but at a greatly reduced price (kind of like generic drugs). You don't have to add anything to the pool to 'make the change', just use them to adjust your chems when you need to adjust. Bleach (unscented) - 'ultra' usually gives you a little more bang for your buck, when you want to raise the chlorine in the pool or have to shock. Use baking soda to raise your total alkalinity - it's tha same chemical as 'buffer plus' or alkalinity increaser - only it costs a lot less and it's purer (you can use it to make cookies ) Use Borax when the pH is low, rather than soda ash or pH plus (this is the only one that isn't exactly the same chem as the pool stores sell, but it's a better way of doing the same thing, AND it's cheeper).
    As for burning through a lot of chlorine, you need to have some cyanuric acid in the water to protect the chlorine from burning off, if your builder hasn't already added some you need to test for it and add accordingly (look around the forum and Poolsolutions for the levels you would like to keep and why). As for the unstable pH, it's normal for pH to be high when a gunite pool is curing, again - look around the forum, you'll see it's very common and learn what others here have done about it. As for order of treatment, chlorine must be the first thing to raise if it falls too low - it keeps the water sanitized. Many recomend that pH be your next priority (some of the equiptment can be damaged by improper pH).
    This answer is woefully incomplete, but should get you started and alieviate your fears - your homework assignment is to find out why I think my response is inadiquate (answer on request )
    Tennessee
    Gracy
    Don be afraid of your pool. I came to this forum a few weeks ago after getting my pool installed. I got nailed on chems from the pool store and then found this forum. I have of the clearest pools around the block thanks to the pros here. Water bear, waste, Carld, and the rest of the great folks here wont stear you wrong. So read, listen, get your self a good test kit, list your results here (I am drooling over one of bens kits but have to wait untill next year), and enjoy your pool.
    Later
    Quote Originally Posted by medvampire
    Gracy
    ..Water bear, waste, Carld, and the rest of the great folks here wont stear you wrong....
    Quick! Run down to the pool store and buy every expensive chem they have! JUST KIDDING!!!!
    That's exactly what we DON'T want you to do! Wisely, you've decided on discretion and skepticism.
    Rather than retype EVERYTHING, I'll just hyperlink you to some stickies:
    This is just basic definitions of B-B-B
    http://www.poolforum.com/pf2/showthread.php?t=1652
    This is a step by step procedure for beginners to help understand how to maintain their pool. The second half has a little discussion of concrete pool: When you get there, the recommended level of calcium is 200 to 400ppm (you'll see what that is all about)
    Finally, here's a sticky to the Best Guess table we talk about. I printed it out (nicely formatted) and have it on the back of the door of my home office, at arm's length to this PC!
    http://www.poolforum.com/pf2/showthread.php?t=365
    I hope all of this helps. We've all been there--that moment of panic, of "WOTTLE-EYE-DUE????" as a newbie. It will pass and things will get easier and you'll be able to balance it all like a kid on a bicycle--seems hard at first then you can't imagine not knowing how to do it.
    These stickies are just the foundation...but they should help alot.
    Miami, Florida
    Thank you all for your support. Went to Walmart and got a test kit. All they had at the moment was an Aqua Chem $15 test kit which I got. I can test FC, Ph, Alk,Stab, Hardness. I know I can do better (more precise) but for the next few days it will do. I've been doing alot of reading as suggested and printing out relevant pages as reference. I've also created a "pool book" which is just a binder with 3 sections, pool forum notes / calendar pages to keep #stats on balance and chems added / blank pages for observations. I have a terrible memory and I figure this way I'll be able to refer back. I don't expect to do this forever, but I would guess at the beginning as you all say, you need to get to know your pool and this should help, right? DH says it's like I'm back in school!
    Ok-pool guy should be here any minute so I will have him test and I'll run parallel test to compare. I will post in a separate thread the results.
    Thank you all again.
    Gracy
    Gracy
    Tennessee
    Gracie
    Good to see you are taking to this like a duck to water. The only thing is I belive the Walmart test for total chlorine. Check to see if it says OTO on the label. OTO turns yellow and test for total chlorine. You may want to invest in DPD test kit. I found one that did free chlorine and combined it with the walmart kit untill I ran out of tabs. I found a liquid DPD that gives both free and total chlorine pretty cheep at a pool store.I had them test my water and they tried to sell me more chemicals includeing a copper based wonder liquid.I kinda ticked them off when I passed. The nailed me for around $200 when I first bought the pool. I am drooling to get ones of Ben's kits but I am gonna wait untill next season.
    Later
