Not to be a PITA, but what size box? Is this the "grocery store standard size" or the "Sam's Warehouse Club"Originally Posted by aylad
box? Can you give your recommendation in cups or something? Thanks!!
I'm sure she is talking about the standard grocery store size box.
Yeah, Watermom's right, as usual. Sorry, I rarely have to use it, so I only get the grocery store box.
Thanks to all --- Glad I could add a bit of humor for all. Next step will be Bleach --- downloaded the calculator. Problem is I have lots of pucks and Cal Hypo left.
May try a liquid shock today -- smelling the chloromines just a bit, soooo.... Do need to add OTO to my DPH kit so I can look at the higher CL Levels.
If your calcium level isn't too high (more than 200 or so for a vinyl pool, then you can still use the cal-hypo to shock if you want to--you just don't want to let it get high enough to start precipitating out of the water. Tightly cap your trichlor picks, and you can use them at the beginning of next season when you're trying to raise your CYA again.
OK --- that sounds reasonable --- Perhaps I should start another thread for this question.
I have never seen a difference when I test for total chlorine. Using a DPD test kit --- Fresh reagents and careful attention to procedure. Free chlorine now is between 2 & 3 when I add the 5 drops of R0003 nothing changes. We shock regularly (once per month) and I really don't want to see any combined chlorine but I would think I should see something. Perhaps I shock too often??
You shouldn't necessarily see any CC. I never do. It just means you are keeping your chlorine levels up adequately.
