Results 1 to 9 of 9
Thread: 220V vs. 115V. What's the difference?
    Default Re: 220V vs. 115V. What's the difference?
    OK then, so I guess it really doesn't matter in the grand scheme of things. I wanted a Whisperflo 2 speed (uprated 1HP - full rated 3/4 HP is $80 more ) which gives me perfect GPM for my pool. The 220V models are too powerful. This saves me from rewiring for 220V, buying a new timer and probably getting a shock or two in the process (kidding of course).
    Thanks,
    Joe
    Tucson, AZ, USA.
    The difference between 220 and 115?
    105!
    Quote Originally Posted by cschmelz
    105!
    Thanks everyone for coming. cschmelz will be here all week with another show at 9:00pm
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    Go with 220V when possible. The same HP motor will require twice as much current (amps) at 110V compared to 220V. As was stated previously, you will need a significantly larger wire size at 110V for this reason.
    Also, the start up current of a motor can be 6 to 12 times the amount of the running current (FLA). With 220V you are drawing less current and spreading it over the 2 halves of your electrical panel, which I believe is less likely to cause lights to dim, etc.
    Unfortunately every 2 speed 220V pump moves too much water for my application. Looks like a Whisperflo 1 HP uprated 115V pump for me. Wish I could have done it but the 220V 1 HP pump moves 90 gpm (115V 70gpm) which is overkill for my 16,000 gallon pool.
    Thanks,
    Joe
