Results 1 to 10 of 29
Thread: So how come there aren't a LOT of sick people?
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Default Re: So how come there aren't a LOT of sick people?
    This makes no sense to me......
    I thought the reason concluded behind SWG companies all suggesting 80ppm CYA was that you could maintain a lower chlorine level.
    Does this chart state that SWG owners need at lease 5ppm Chlorine to have a safe pool? I dont think my SWG will generate that much.
    Some people have hobbies.....I have a pool.
    IL.
    My understanding is that it's different for SWG pools, as the cells are basically super chlorinating the water continously (as long as they're running), so less of a residual is needed in the pool.
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    http://www.ppoa.org/pdfs/PrP_Cyanuri...0or%20Bomb.pdf
    it makes for an informative read . And even if I never read anything about CYA, I know whats working in MY pool. Before I found this site , I couldnt figure out why my pool was such a pita. When I learnt to deal with the high cya , the pool looks great , less work and more fun. dont need to prove anything else to me
    Central Texas
    Quote Originally Posted by CToon
    Great article, thanks!
    I use the liquid bleach regimin too after visiting this site, and I also have great results. Just trying to understand a bit more of the why.
    TW
    Tennessee
    I work in a hospital laboratory and see peps that are sick from pools. The reason you don’t hear about it is because the environmental source of infections are hard to identify. I would venture most middle and outer ear, eye infections, and wound infections in families with pools are pool related. I have seen skin infections caused by Pseudomonas from pools. I have seen respiratory infections form pools and spas. I read an article a few days ago about pathogenic E.Coli transmitted by pool water. Its there you just don’t hear of it very much. I feel that if you are seeing algae you have a higher risk from pathogens in the pool as well. If our immune systems are functioning well we can fight off mild attacks but in the young and elderly populations are at higher risk.
    Quote Originally Posted by medvampire
    The reason you don’t hear about it is because the environmental source of infections are hard to identify. I would venture most middle and outer ear, eye infections, and wound infections in families with pools are pool related....
    Makes sense. Though I'm no doctor or even in the medical field, that is essentially what I've always suspected.
    Dave
    Since folks are stating their credentials fwiw (for what it's worth), I'm an RN BSN (LLU), with a PHN certificate. I worked as an RN for over 20 years, received a graduate degree in engineering and moved along.
    The CDC (Center for Disease Control), started tracking WBDO (Waterborne Disease Outbreaks) associated with RW (Recreational Water) in 1978 so that's as far back as their statistics go. The latest surveillance summary I've seen is dated 2002. You can read it here:
    http://www.cdc.gov/mmwr/preview/mmwrhtml/ss5308a1.htm
    Next CDC only tracks clusters and reporting is voluntary the above is an interesting read and gives you a window into RWI (Recreational Water Illness). Since this leaves out the large population of RW, private swimming pools and individuals owners/swimmers you can surmise that this is simply the tip of the iceberg.
    While I wouldn't go quite as far as MedVampire does
    I'd say he's pretty close. The only reason I don't completely agree is the large groups of pink eye (infectious conjuctivitis), uri's, impetigo, scabies, tineas, pediculosis and diarrheal illnesses amongst the pre and elementary school population.
    It's very important to remember drowning is also an RWI and probably the easiest preventable one.
    Jo
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by Tredge
    SWGs are different. See this thread:
    http://www.poolforum.com/pf2/showthread.php?t=3185
    Mark
  1. Hello Pool People
    By Cloud26 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2011, 11:55 PM
  2. Help with 6 port valve - no PSI - pop up filters aren't working
    By bortoldr in forum Pool Equipment & Operations
    Last Post: 11-11-2010, 02:02 AM
  3. Help! I'm sick of vacuuming.
    By shadowman in forum Pool Equipment & Operations
    Last Post: 06-14-2007, 12:41 AM
  4. My Dolphin is sick!
    By jdolby in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-25-2006, 11:29 PM
  5. Ok people - I'm on my own - HELP!!!!!!!!!!!!
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-01-2006, 08:05 PM
