Re: My turn to ask questions
Hi, Karen,
I would suggest the following:
1. More accurately calc the gallons in your pool. Within 1k or 2k for that size pool is fine. 1 cu. ft. of water = 7.48 gallons.
2. Download bleachcalc from any of mwsmith2's posts...put it on your desktop...you'll use it all Summer.
3. Buy enough Cl to get your ppm up to 15 if it's vinyl lined, 25ppm if it's plaster.....buy plenty...you'll use more soon.
4. buy enough CYA to get to 30+ppm...40 is a good target.
5. Add the Cl to your pool at dusk....do this as soon as you can...you currently have no protection from algae. Test again just before you go to bed and add enough to bring it back up to 15ppm/25ppm. Repeat this procedure 'til your water is clear. It may take a few days.
6. During this procedure, run the pump 24/7 and backwash each time your filter pressure raises by more than 8psi or so.
7. When your water is crystal clear, backwash one last time and add the CYA directly into the skimmer, pump still running. It'll take the CYA a few days to dissolve and show up on your test.
8. Lastly, maintain a constant Cl level between 3-7ppm the rest of the Summer and your pool will sparkle the whole time.
Post back questions any time...lots of help here on the forum.
