Results 1 to 10 of 49
Thread: Taking the Plunge - Baquabeast conversion starting
    Default Taking the Plunge - Baquabeast conversion starting
    Hey all,
    Well after weeks of dealing with milky water, and reading every post on this forum and spending several hundreds of dollars of that Baqua Junk that I fell for, my hubby and I decided to go ahead and convert.
    Didn't want to lose any swim time, but this is supposed to be a cruddy week here in Jersey and the pool is a little cool for the kids, so I guess this is the perfect week to attempt this
    I'm quite nervous about it, but confident that with your help, we can do this and have a sparkling pool in a few days. I hate looking at this milky water stuff.
    Off to buy bleach and a test kit. I would like to order Ben's but we have to do this now and I can't wait.
    Does it matter what concentration of bleach I use, whether 6 % or 12 %. I know to use the bleach calculator to get appropriate amounts, but is there a difference???
    And I assume pool filter is to run 24/7
    Wish me luck
    Default Re: Taking the Plunge - Baquabeast conversion starting
    It does not matter what concentration of bleach you use. Yes to running the pump 24/7. Be prepared for the water to turn green! But, it will be well worth it. Good luck and keep us posted how it is going.
    Thanks Watermom.
    I will post numbers as soon as I can.
    I will go out for the bleach this evening and begin dumping tonight.
    Here's another question:
    Since I've only used Baquacil, I'm guessing I will not have any cya in the pool??? So I can type 15 ppm into the bleach calculator and not have a problem with too much bleach and fading my liner?
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    15 PPM will be fine. As soon as you dump the bleach in it will start attacking the Baquacil. It is pretty cool when you first start pouring it in when it starts changing colors. Did my conversion last year and couldn't be happier. You need to buy A LOT of bleach. I have an 18 x 36 IG pool and used around 75 jugs. You need to test and bump back to 15 PPM 3x a day and backwash often. Watch your filter pressure. It took me about 4 days to convert, and my water is simply amazingly clear now, with no algae. Good luck, and post any questions you have. Keep us updated. I posted pics of my conversion from start to finish if you want to see what you are getting ready to face. Look on the first page of this thread.
    Voldaddy - your thread is one of the reasons I pushed my hubby to do the conversion.
    I plan on taking lots of pictures. Although I warn you, the area around the pool is not pretty. We plan on putting a full wrap around deck up, so right now we are in the process of backfilling.
    18X38 AGP 52 inch wall with a 6 1/2 foot deep end
    With all the backwashing that needs to be done, did you add back any water??
