Results 1 to 10 of 12
Thread: Mud in pool
    Default Mud in pool
    We just had about a foot of rain, which caused a flash flood. My pool filled up with mud water and is completely brown. Now the very fine layer of brown silt has rested at the bottom of the pool. The silt is so fine that the filter does catch it. I have a 18,000 gal, IG, not sure the type of filter. Any ideas to get it out?
    Tennessee
    Default Re: Mud in pool
    You need to find out what type of filter you have and post for the pros here to answer you better than I.You may want to get a skimmer sock or let it settle out and vacume to waste.
    West Texas
    The filter should say something like D.E, Sand filter or cart on it.
    Anyhow, just because it's setting there at the bottom doesn't mean the filter want catch it. The pool just needs a good vacumming. I would keep an eye on the pressure to make sure it's not to high and nor does it get to high while vacuuming that much junk. In some cases, I'll vacuum that stuff to waste, meaning it never goes to the filter but to the drain. Keep in mind this will drain some water from the pool....all of it if you leave if on waste for a while You may want to Back wash the filter if it's a sand before hand or clean it if it's a cart filer after wards. Also they make some Water clearafier thats works pretty good. It attaches to the fine particals in the pool causing them to fall to the bottom and be vacuumed up. .
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    I woke up this morning to a green pool for the same reason - lots of brown dirt flowing in overnight. I shocked it to the highest levels, put a cut off leg of panytyhose which is like a skimmer sock on, and have my pool cleaner in. The water is already almost blue, and the skimmer sock is dirty, I have already rinsed it off 2 x. I also brushed down the pool to get any dirt of the sides and steps. I also added some metal sequestering agent in case there is anything in the dirt.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    Thanks for the input. I will check to see what type of filter I have. Can you tell me where you intsall skimmer sock?
    West Texas
    Quote Originally Posted by mbar
    If you haven't done it yet, you may want to vaccum the pool again. All the loose floating Alge will die and fall to the bottom of the pool. I usualy will vaccum this to waste if it's real bad.
    Good job in getting her blue again.
    Occupation = Amature Pool man.
    NO I'm not here to sell or promote anythihg...well I do fell pretty strong about DE filters Just trying to futher my trade and maybe help someone in the process.
    IG Pool & Spa...about 15,000 gl and a DE filter w a 2hp Sta-Rite pump.
    mbar's Avatar
    Ashland, PA
    Pool is crystal clear today - I did vacuum to waste this morning. Now for the basement carpet!!!
    Northeast PA
