Results 1 to 10 of 12
Thread: Pool newbie-- possible baquasil
    stelr92 is offline ** No working email address ** stelr92 0
    Default Pool newbie-- possible baquasil
    First of all let me say that I dont know anything about pools and I was really happy to stumble upon this website. I just purchased a 25 year old home and it has a small above groud pool in the backyard (24 feet?). I have no idea how old the pool is or how long it has been sitting winterized. The pool itself is in kinda rough shape, it looks like the cover has been on it for some time due to the dirt and other junk laying in the water that was on the pool cover. Also there appears to be a rust hole just above the water line where it appears the liner could pooch out of if i fill it above that level. I was thinking about taking a piece of vinyl and putting it in the hole, so that the vinyl doesnt get damaged by the rust hole. Is this a good idea?
    Today I finally got the courage to see what was lurking beneath the cover. When I lifted it off it appears to be in pretty good shape, it is about half full, with a little dirt on the bottom, and there were 4 dead froggies that I had to fish out, but other than that the water color is good, and i dont see any algae on the sides.
    I think the previous owners used baquacil because there is a box under the deck that says baquacil on it. Since I just bought the house, funds are limited and I have a couple questions regarding the conversion process. Assuming that they did actually use baquacil, do you think a conversion will be necessary? If so where is the cheapest place to buy bleach/chemicals?
    I plan on taking a few bottles of water from the pool to my local pool store to see if they can test for baquacil tomorrow. Is there anything else I should be concerned with?
    Tennessee
    Default Re: Pool newbie-- possible baquasil
    First of all I would be concerned about the hole. I am not an expert but there are plenty here. Can you post a pic of the hole?
    There is a procedure for conversation from baq to chlorine. I again am not an expert but you will find the answers here on how to.
    I would recommend a good test kit. Ben sells the best here.
    Most of the people here use common chemicals found at your supermarket for their pools with great results at a lower cost.
    Listen to the pros here they have been there done that and will move you in the right direction.
    If you go to the pool store go with a open mind and a closed wallet. This entire site is devoted to preventing us newbees from getting “pool stored”.
    Read as much as you can here and at the sister web site.
    Good luck
    Rehoboth, MA
    I'm with Steve - I would get the hole under control first. Go look in the Above Ground Pool section in this forum about repairing holes and if you don't find the information you need there then post a new thread and you will get some help. As Steve suggests, a pic would help if you need to post your question.
    Once you get that squared away (and you get your first water sample test results) then you can work on water chemistry. One thing I would do though is to check your pH right away as low pH (6.8 or lower) can cause liner damage.
    Peter
    I have a pic here that I will be posting shortly as soon as webshots confirms my account. Started to fill the pool today and added some shock to see what came out, it immediately turned rust colored so I am assuming there was quite a bit of bacquacrap left in the pool. Right now my chlorine level is about a 4, and ph is at about 7.8 or 8. I'm off to buy some stuff to get the ph down, and a whole lotta bleach. Also there is a small leak coming from the filter door thingee because one of the screws is stripped preventing it from making a good seal with the pool.. Think I'm gonna duct tape it for now. From reading this forum, I think I'm going to need to add something to lower the ph, and once that is done, I'll go nuts on the chlorine, and bring it up to 15ppm. I'm also going to try to get a better tester, as the one I have now only tests ph and cl.
    Okay, so here are the pics of the pool today. Is this what you would expect?
    http://community.webshots.com/myphot...ecurity=PAYHvO
    Tennessee
    Looked at your pics. Untill you get a better tester the chem problems are gonna be hard for the pros here to help you. Didnt see a pic of the hole. I would be more concerned about it. You might use some jb weld and thread releaser in the skimmer to reform the threads. I would lower the ph after you get the pump going. Need to mix the acid and chlorine. The red color may be a iron problem but I am not a chem pro. You might want to get a metals test at the pool store.
    Later
  1. Pool newbie
    By Limeybiscuit in forum Pool Equipment & Operations
    Last Post: 03-27-2017, 12:20 AM
  2. Pool Newbie
    By blazin in forum --cleanup--
    Last Post: 10-20-2012, 12:04 PM
  3. Pool Newbie
    By warren_tax in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-18-2012, 05:15 PM
  4. I am a newbie here and with pool
    By raptureready1953 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-02-2006, 03:44 PM
  5. Newbie with a Fox Pool...
    By mariner09 in forum Pool Equipment & Operations
    Last Post: 06-13-2006, 12:08 PM
