Re: Pool newbie-- possible baquasil
I have a pic here that I will be posting shortly as soon as webshots confirms my account. Started to fill the pool today and added some shock to see what came out, it immediately turned rust colored so I am assuming there was quite a bit of bacquacrap left in the pool. Right now my chlorine level is about a 4, and ph is at about 7.8 or 8. I'm off to buy some stuff to get the ph down, and a whole lotta bleach. Also there is a small leak coming from the filter door thingee because one of the screws is stripped preventing it from making a good seal with the pool.. Think I'm gonna duct tape it for now. From reading this forum, I think I'm going to need to add something to lower the ph, and once that is done, I'll go nuts on the chlorine, and bring it up to 15ppm. I'm also going to try to get a better tester, as the one I have now only tests ph and cl.
