Re: Testing for CYA
Sounds like your level is about 40-50. That's probably accurate enough for you to understand the necessary chlorine levels to maintain.
I've received several good tips here on getting more consistant CYA Test results.
Assuming your already using a liquid test and not a test strip;
Make sure the dot has disappeared completely when you take your reading. This is sometimes easiest to judge holding the tube at waist level outdoors, but out of the direct sunlight.
I try to shake up the solution, let it sit a minute, shake it some more, let it sit (while I do other tests.) If you have any question about the reading, pour it back out of the tube into the bottle, and try again, no need for another water sample or more solution
