I didn't know you could buy just a heat pump. Our pool is only 10,000 gallons. I'll have to look into it as well. I just know I don't only want solar b/c I want to heat more than 10-15 degrees. The thing down here is sometimes you'll have an 80 degree day in the winter, but then it'll drop to 50 degrees the next day so it keeps the pool from staying at a decent temp. Plus we have a lot of shade trees which doesn't help. Thanks for your input!
