Results 1 to 10 of 28
Thread: gas vs. electric heater?
    Honesdale PA
    Default
    I guess I'm thinking more from an efficiency standpoint for house A/C as opposed to trying to extending the swimming season. Here in Northeast PA pools normally don't get too warm on their own unless we have a really hot spell. I'll take every BTU I can get to heat the pool.
    Green Bay, WI
    Default
    That was my thought as well. Since we always need heat for the pool it isn't an issue. I just use the heat pumps for cooling the house as necessary and any additional heat that ends up in the pool offsets the gas heater. I did find about 20 hours a day or more will increase my pool temp. Although it is pretty rare I needed that much cooling. In those cases the central AC would just pick up the slack. Again it is a win-win.
    I actually run off peak rates so I typically run the heat pumps and pool pumps off peak unless it is really warm. Our modest solar array picks up about 1/2 the loading of I do run on peak.
