Thread: Baker-Hydro spider gasket turned to goo.
    Central Texas
    Default Re: Baker-Hydro spider gasket turned to goo.
    Well that was an interesting adventure. One pool store wanted $140 for a 'valve kit' because "they don't make that valve anymore." Another had a Hayward gasket for $11 that fit perfectly.
    Smile Re: Baker-Hydro spider gasket turned to goo.
    #1 was trying to, in CarlD's words, "pool store" you, glad you found the cheeper alternative and that the problem's solved!
    Central Texas
    One other thing...
    Most of the old gasket came out in one piece, but there were areas that seemed like they were glued in. I cleaned the grooves as best I could and then used silicone lubricant to seat the new gasket. But what keeps the gasket seated in the groove? What stops it from sticking to the diverter head and getting lifted out of the seat?
    Quote Originally Posted by aquarium
    One other thing...
    The lube usually keeps it from comming out, that and the fact that the channels are (on most multi's) deep enough, some recommend glue, but I disagree. If you want to secure the gasket, I recommend some silicone caulk, (yesterday I went to a pool to replace the grids and the 'spider gasket' - the d*mned thing had been CRAZY GLUED in and getting it out with a screwdriver only damaged the unit) So instead of just replacing the gasket, I had to give them a whole new multiport - we never did get all the glued in gasket out.
  1. Need a Hayward spider gasket
    By Bkirrane in forum Pool Equipment & Operations
    Last Post: 05-28-2012, 10:30 AM
  2. Hayward spider gasket replacement
    By briel in forum Pool Equipment & Operations
    Last Post: 05-24-2012, 10:20 AM
  3. Spider Gasket
    By markphin in forum Pool Equipment & Operations
    Last Post: 05-21-2012, 01:18 PM
  4. Spider Gasket - First Obsticle
    By Sprint54 in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2006, 10:31 AM
  5. Replacing Spider Gasket
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 11:49 AM
