Results 1 to 10 of 11
Thread: Cant Find Answer Now
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Cant Find Answer Now
    I read a post before but cant find it now. I was using Trichlor tabs in my feeder and now my CYA is at 40. Im going to stop using the Trichlor but would like to keep using the feeder. What is the name of unstablized chlorine tabs? Are they the same as the trichlor just no CYA?
    John
    IL.
    Default Re: Cant Find Answer Now
    I think you are referring to calcium hypochlorite tabs.
    No CYA but they'll add calcium to your water, which may or may not be a good thing.
    I have a vinyl liner, does calcium matter? Id just like to regulate my chlorine level a little more for times when Im not arround.
    John
    Berwyn, PA
    I think this was the thread. Doesn't sound too promising, and sounds like they're for a skimmer, not a feeder.
    http://www.poolforum.com/pf2/showthread.php?t=500
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    I think that tri-chlor tabs are the only well suited tabs for a feeder.
    I would not use any other tabs in the feeder especially one that was already used with tri-chlor.
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    Quote Originally Posted by jrv331
    John
    Under no circumstances should you put anything other than Trichlor in that feeder, even if you think you've cleaned it out well enough. Mixing chemicals is very dangerous and it only takes trace amounts to have a reaction.
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
    Thanks for letting me know not to use any thing else in the feeder. What were the tabs others have been putting in nylons , then in the skimmer basket?
    Althought getting harder for me as Im away so much lately looks like I just may have to stick with bleach.
    John
    NO! NO! NO! NO!
    Under NO CIRCUMSTANCES should you EVER mix types of chlorine in a feeder--it is very, Very, VERY DANGEROUS!!!!!!!!
    NEVER, EVER USE A CONTAINER/FEEDER FOR MORE THAN ONE TYPE OF CHLORINE...THINK SKULL AND CROSSBONES!!!!!
    Thank you Carl!
    Carl,
    VERY well said! I just don't think you empasized the danger enough! (and I'm being serious!) It's more than skulls and crossbones....more like exploding fire and brimstone!
  1. Difference Between Liquid Chlorine and Household Bleach
    By sun and water in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-03-2012, 08:32 AM
  2. Newbie, I think I know the answer but....
    By healthservices in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 11:42 AM
  3. need a easy answer???
    By larry b in forum Pool Chemicals & Pool Water Problems
    Last Post: 10-06-2006, 12:32 PM
  4. SAM vs JAZZ Need quick answer
    By columbo in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 05:25 AM
