Didn't know about the floor cleaners. That changes the situation somewhat if you want to use them. You will need pretty high flow which will lead you toward a higher HP pump. You need to find out what flow is required for each cleaner and make sure the pump can supply the total. I would lean more towards a 2-speed pump so that you can have the high speed for cleaning and low speed for general circulation.
