Results 1 to 10 of 13
Thread: Pump too big for pool, read some posts on reducing flow with ball valve
    Sugar Land, Texas
    Default Re: Pump too big for pool, read some posts on reducing flow with ball valve
    nicole,
    I don't know how much you pay for electricity, but I'm guessing that it's not cheap up there in MA.
    Considering the cost of the new valve being talked about and the unnecessary horsepower being used, you'll probably be money ahead if you replace the pump now.
    Of course, cash availability is always a consideration...
    When you throttle a pump on the discharge you lower its HP draw as well.
    Honesdale PA
    Actually what is happening when you restrict the flow on the output side of the pump is to increase the pressure, reduce the flow, and thus reduce the work that the pump has to supply. The reduced work load, i.e. moving water, results in a slight decrease in power consumption. Opposite to what may seem intuitive. These comments apply to centrifugal pumps only, which all pool pumps are as far as I know. I agree that in the long run the cheapest option is to replace the pump.
