Did you use a copper algacide? Copper in the water will turn blonde hair green.
Northeast PA
Sounds like copper to me too. Does your pool have a bit of a green haze to it also? Copper is not fun to get rid of and leads into more water problems like I just went through. Took us about 2 weeks to recover from our copper issue and get things started back to normal.
I've heard the 3 most common causes of copper are:
1) Pools with heaters (this was my problem)
2) Using too much algecide (the kind that contains copper)
3) Filling with well water
Considering the fact that you just treated an alge issue, you might want to take a peek at the back of your algecide bottle. If it contains copper and your wife's hair is turning green you might want to look at getting some metal control. Remember you can't treat metal until your chlorine level drops to below 1ppm.
My fingers are crossed for you that its not copper though. One thing to also check... anyone getting blue fingernails? I've heard that is also a sign of copper in the water. Bring it to your local pool store and make sure they test for it. We found out that our pool store doesn't normally do so unless you ask. That's how ours got out of control.
what did you use to shock the pool ??
Pool store stuff often contains copper ( makes green hair etc ) and some have lots of calcium that can percipitate out making milky water.
This is why the methods on this formum almost always suggest using plain bleach. There's nothing else in there to screw up your hair of turn the pool milky.
You also need to tell us what your free chlorine and total chlorine is. Without knowing that we can't tell if you have any, or much combined chlorine. That will give us a pretty good idea if you still have algae in the water or minerals causing the milkiness.
Algicide should only be added AFTER the algae is killed off, and even then it is optional. Many of us on this forum find that chlorine is all that is needed. Some add algicide as a " belt and suspenders both" program. In any case the only algicide to use is the poly quot 60%. It will not cause foaming and will not turn your hair green(er).
