Thread: what makes the ph go up?
    Question what makes the ph go up?
    Hey all, This year my ph keeps going up. This is our 4 season and we have never had this problem before. What could be the cause?
    Water #s
    PH7.8+
    Alk 110
    cal 180
    cya 30-40
    tc 4.0
    cc 0
    fc4.0
    we have a steel/vnl inground/heat pump
    26,000
    Thanks,
    Ed
    Default Re: what makes the ph go up?
    Were you using pucks in the past and bleach this year? That will do it. Pucks drop your pH while bleach raises it. That is why I use half pucks and half bleach, then I never have to mess with my pH by added separate chemicals. When it is low I use bleach, when it is high I use pucks. I don't worry about CYA going up as water naturally gets lost due to backwashing or on weeks like this where I got 7" of rain and had to pump out that much water.
    pH rise can be caused by many things, among them use of bleach or cal-hypo, aeration of your water, curing plaster, or sometimes your pool will just find its "normal" level and want to stay there.
    Thanks for all the help. My Ph is down to 7.3-7.4 and holding steady . My alk is at 80-90 or so after a ton of rain.
    Cheers,
    Ed
  1. multiport makes clinking sound
    By jdolby in forum Pool Equipment & Operations
    Last Post: 06-17-2011, 09:30 PM
  2. what makes eyes sting in the pool?
    By pairadocs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-21-2006, 02:31 AM
  3. Who Really Makes Mineral Springs SWG?
    By bhelme in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-17-2006, 02:14 PM
  4. Who makes Tahitian Pools & are they good
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 04-16-2006, 03:22 PM
