Re: Pool store advice to lower alkalinity - three day muriatic acid dose method
it's the 'accepted' method and it doesn't work very well. the idea is to pour a shot of acid in the still pool and the pocket of low pH will cause the carbon dioxide to bubble off....sort of like pouring vinigar on baking soda (which is pretty close to what your are doing!) I have read some descriptions of it where they say you can see the bubbling occur! You need to lower the pH and then aerate if you want to do it so it works!
See this thread
http://www.poolforum.com/pf2/showthread.php?t=191
