Results 1 to 4 of 4
Thread: SWG safe for heater?
    Default SWG safe for heater?
    Hi All,
    Considering an SWG but a friend converted to salt and said his pool company had to replace his heater because it wasn't compatible. I just bought my Sta-Rite Max-E-Therm and have no plans to replace it. Anyone have any opinions? I didn't see anywhere in the manual where it says no salt water. It says fresh water only but i thought 3000ppm of salt is still considered fesh water
    Thanks,
    Joe
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: SWG safe for heater?
    If you have a copper heat exchanger there could be problems. If you have a titanium heat exchanger or one of the coated ones it should be fine.
    Thanks. NOt sure which exchanger I have. Maybe rpoldervaart can chime in since he has the same heater and an SWG
    Sta-Rite said as long as the salt concentration doesn't exced 3500ppm I am OK to use my heater. I Was worried there for a bit. NOw I have to decide which generator to buy.
    Joe
  1. Are These Numbers Ok/Safe?
    By tokmom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-26-2012, 11:17 PM
  2. Safe to empty pool?
    By mkelley in forum Pool Equipment & Operations
    Last Post: 07-12-2008, 10:34 PM
  3. what cl level is safe?
    By Bergerman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2006, 03:00 PM
  4. Safe for swimming?
    By kevincad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-21-2006, 09:53 AM
