Results 1 to 10 of 15
Thread: Considering Adding Water Softener Salt to Pool...
    Richmond, IN
    Default Considering Adding Water Softener Salt to Pool...
    Hello,
    I am considering adding to water softener salt to my pool via my now unused puck chlorinator.
    Has anyone else done this?
    Does it impact the chemistry (ie, chlorine, ph, alk., etc.) levels in the pool? What consequences should I expect? Does it make the water nicer to swim in?
    Any comments/advice would be appreciated.
    Thanks,
    Paul
    Winston Salem, NC
    Default Re: Considering Adding Water Softener Salt to Pool...
    Quote Originally Posted by psbailey
    Hello,
    Thanks,
    Paul
    I hate to jump in on another persons question, but I too am interested in adding salt to my non-SWG pool. I thought instead of starting another thread, we could share the information.
    Where Paul would be using his unused puck chlorinator, I would be just dumping the salt in the pool.
    I've read where is it softens the water, but what are the other advantages to adding salt to a non-SWG pool?
    What are the cons or problems one may encounter by adding the salt?
    I know, that the amount of salt added would depend on pool size/gallons held, but what would be the approximate PPM that one should shoot for?
    I know that I have read other threads concerning this, but can't seem to locate them now.
    Mark
    nc.
    Southeast N.C.
    Home of the Monster Bugs!!!
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    No reason to use a chlorinator. Just dump it in. It'll dissolve in an hour or so.
    Go ahead and do it. It feels great. Just buy a test kit and test your salt content first so you can confirm whether you currently have any salt in there.
    Richmond, IN
    I'll get a saline test kit tomorow. What levels should I be shooting for? I have a 45,000 IG plaster pool. My numbers are:
    Cl: 6
    FC: 0
    TC:6
    PH:7.4
    ALK: 120
    CAL: 320
    CYA: 53(ish)
    Thanks,
    Paul
    Caledon, Ontario, Canada.
    Paul
    I hope your test results were posted wrong.
    FC = 0 and TC = 6 is a warning of an impending frog pond.
    check it out.
