"... The water tastes salty, much saltier than the display pool at the builders( I did taste it). It is at approx 3200ppm.
***SALT TASTE IS DIFFERENT FOR EVERYONE. USUALLY AROUND 3500 PPM IS WHEN YOU CAN TASTE THE SALT IN THE WATER. I HAVE MINE AT 3800 PPM RIGHT NOW AND LOVE IT!***
My stablizer is at 40-45. The purifier is not on very often and when it is running it's at about 20% and I can keep a FC of 5 at about 85 degrees water temp.
***INCREASE YOUR STABILIZER TO AT LEAST 60 PPM, AS PAT SAID. IT WILL HELP. 5 PPM OF FC IS ON THE HIGH SIDE. I WOULD REDUCE THE % EVEN MORE. BETTER YET, I WOULD DROP THE CELL POWER FROM THE FACTORY SETTING OF 2 (6.5 AMPS) DOWN TO CELL POWER 1 (5.0 AMPS). ALSO INCREASE THE PURIFIER % UP TO ABOUT 50%, TEST YOUR CHLORINE AND MAKE ANY ADJUSTMENTS TO BRING YOUR CHLORINE DOWN TO ABOUT 2-3 PM. I KEEP MINE AT ABOUT THAT RANGE.***
Is this all OK or should I increase my stabilizer to the recommemded 60-80. A tech from a different pool builder told me that CYA isn't necessary in SWG pools because they can continuously manufacturer the necessary chlorine and that CYA is banned in California. Is that true?
***HOGWASH. CYA IS ABSOLUTELY NECESSARY AND IS PERMITTED IN CALIFORNIA. OTHERWISE THEY WOULD OUTLAW THE USE OF DI-CHLOR AND TRI-CHLOR TABLETS, WHICH BOTH CONTAIN CYANURIC ACID. THE ONLY PLACE THAT I KNOW OF THAT DOES NOT ALLOW THE USE OF CYANURIC ACID IS FOR COMMERCIAL POOLS IN NEW YORK, AND EVEN THEN, THERE ARE A SPECIAL EXCEPTION CLAUSE TO ALLOW THE USE OF IT.***
I have read other posts saying they are successfully running their SWG's with very low CYA.
Also, it was suggested I lower my SWG level to 1(at 2 now) and raise the output. I thought it was better for the cell to run it at a lower setting. What does changing the levels do?
***LOW CYA MEANS THAT YOU HAVE TO GENERATE MORE CHLORINE IN ORDER TO MAINTAIN A RESIDUAL, WHICH IN THE LONG RUN MEANS YOUR CELL WILL FAIL FASTER. CAN IT BE DONE? SURE, BUT AGAIN, YOU HAVE TO RUN THE CELL MORE, WHICH WILL WEAR IT OUT QUICKER.
RECOMMENDATIONS: INCREASE CYA, DECREASE YOUR FC LEVEL, GET USE TO THE SALTY TASTE (IT SHOULDN'T TAKE LONG TO GET USE TO), AND ENJOY YOUR POOL. LASTLY, ADJUST THE CELL POWER LEVEL AND THE PURIFIER %.
IF YOU NEED INSTRUCTIONS ON HOW TO CHANGE THE CELL POWER, PLEASE E-MAIL ME DIRECTLY. [email protected]
***and thanks for selecting Pool Pilot***
